    _api Project File Unloaded
    5 Posts 0 Posters 625 Views
      On 18/03/2009 at 05:32, xxxxxxxx wrote:
      Cinema 4D Version:   11
      I'm trying to resume work on a plugin in Visual C++ 2008 Express Edition after a 2 month hiatus.
      The Visual Studio Conversion Wizard appears, saying that the project being opened was created in a previous version and must be converted.
      After conversion, the Solution Explorer says that the _api project file was unloaded. Reload Project is unsuccessful.
      I haven't changed anything since last working on the plugin, when all was well.
      Can anyone provide a solution to this problem?
        On 19/03/2009 at 04:52, xxxxxxxx wrote:
        I have no idea, sorry. Currently VS2008 is not officially supported by MAXON, meaning you have to use it on your own risk.
          On 19/03/2009 at 05:15, xxxxxxxx wrote:
          Okay, thanks for the reply.
          I might have to give VS 2005 a try.
            On 19/03/2009 at 05:51, xxxxxxxx wrote:
            Why not simply adding the api project back on yourself? 😉 Then simply set the dependancies again. Should be it (drag and drop the project file of the api into the project window of VS).
            > Quote: _Can anyone provide a solution to this problem?
            _
              On 19/03/2009 at 06:03, xxxxxxxx wrote:
              Okay, it's working!
              The problem was that somehow _api.vcproj had become write-protected, which was preventing it from being converted.
              > Quote: Originally posted by 3D Designer on 19 March 2009
              Thanks for the suggestion, this helped put me on the right track.
