    brackets stay in path
    6 Posts 0 Posters 467 Views
      On 10/03/2009 at 11:42, xxxxxxxx wrote:
      Cinema 4D Version:   10.1
      i have a script that loads a texture into a material channel.
      i can get texture to load if the texture is in the same folder as project with filename as eg.. "texture.jpg".
      but if i try to load it from a different folder eg... "c:\Folder\subfolder exture.jpg"
      it loads the path as "c:Foldersubfoldertexture.jpg"
      does anyone know how to get the brackets to stay in the path?
        On 10/03/2009 at 20:18, xxxxxxxx wrote:
        i dont know if this will make people understand more but i said the wrong name.
        its meant to be "back slash" \ (not bracket)
          On 10/03/2009 at 20:56, xxxxxxxx wrote:
          never mind.
          i got it working.
          i had to add double back slash
          eg... change c:\folder\image.jpg to c:\\folder\\image.jpg
          (just incase someone has same problem)
            On 11/03/2009 at 14:16, xxxxxxxx wrote:
            It is generally better to use AddLast(folder or file name) to construct the path instead of writing it directly. This also makes sure it is plattform independently generated I´d say.
              On 11/03/2009 at 15:07, xxxxxxxx wrote:
              that wont work?
              because im using it to load a texture to a material (same material all the time)then apply it to an object.
              wouldnt "AddLast(folder or file name)" just use the last path a browsed to.
              which i dont wont because i could change the path, which would make the code not work anymore
                On 11/03/2009 at 16:15, xxxxxxxx wrote:
                What I mean is something like this:
                Filename fn = "C:";
                fn->AddLast("folder");
                fn->AddLast("image.jpg");
                You shouldn´t explicitly define the path as you did. It doesn´t matter how you use it, I am talking about the compatibility of the path construction if you know what I mean.
