    DescLevel, DescID, part 1502
    6 Posts 0 Posters 441 Views
      On 03/03/2009 at 02:13, xxxxxxxx wrote:
      Cinema 4D Version:   11
      Platform:    Mac  ;
      Hi 🙂
      I am sorry, but whyever, my head don't want to understand how to work with this stuff seriously.
      I rewrite the part where to get/set values of BaseList2D objects. For example: To get a segments count of a sphere you can just call
      Sphere[1111] => Returns "24" on standard
      To return the first userdata element you can call
      Sphere[USERDATA_ID, 1]
      That looks nice and is easy to understand, but I have a problem to understand how to get a level down in an element ( depends on the element type, yes).
      For example, to get the x element of a vector I guess I have to check a new Level. How would you access this. Please note, you don't know the type of it.
      I thought I could do this
      Cube[1100, 1000] = > 1100 is the vector of the cube size and 1000 is the X element of it. Yes, I could just call Cube[1000] to return the whole vector but maybe just return the X component would be cool too.
      How would you access this type in C++?
        On 03/03/2009 at 02:26, xxxxxxxx wrote:
        How do you set/get your parameter, with Get/SetParameter()?
        If so why don't you use GeData::GetType() to retrieve the type?
        This is an example how to access a subchannel of the vector type:
        > \> DescID(DescLevel(ID_BASEOBJECT_POSITION,DTYPE_VECTOR,0),DescLevel(VECTOR_X,DTYPE_REAL,0)) \>
          On 03/03/2009 at 02:42, xxxxxxxx wrote:
          Yes, I can use GeData::GetType() when I already got the element, but I don't mean the type of GeData. In your code you use the types: DTYPE_REAL and DTYPE_VECTOR
          That means the user has to call this:
          > \> Cube[ (ID_BASEOBJECT_POSITION,DTYPE_VECTOR, 0) (VECTOR_X,DTYPE_REAL,0) ] \>
          This is just the python way. I would pass these ids to the DescID. In this case I have to pass the type. Could it be possible just to pass:
          > \> ID_BASEOBJECT_POSITION and VECTOR_X without the types? \>
          For example:
          > \> Cube[ (ID_BASEOBJECT_POSITION) (VECTOR_X) ] \>
          which would be much cooler.
          Bye.
            On 03/03/2009 at 03:06, xxxxxxxx wrote:
            Ah, ok, now I got it. I have to do a bit research on my own. I guess it must be possible somehow as COFFEE is doing basically the same.
              On 04/03/2009 at 03:16, xxxxxxxx wrote:
              It seems that you have to get first the typ of each description level.
              For instance to change a cube's X length you would do something like this in Python I guess:
              > \> Cube[ (PRIM_CUBE_LEN) (VECTOR_X) ] \>
              In C++ you have to do something like this:
              - get the type of the first level
              > \> cube->GetParameter((DescLevel(PRIM_CUBE_LEN), d, 0) \>
              - get the type of the second level
              > \> cube->GetParameter(DescID(DescLevel(PRIM_CUBE_LEN,DTYPE_VECTOR,0),DescLevel(VECTOR_X)), d, 0) \>
              - now you all the necessary types to do something with the parameters
              I still have to wait for a final answer of the developers but I think this is how it's done.
                On 04/03/2009 at 05:44, xxxxxxxx wrote:
                yeap, i guess thats it. works fine 🙂 thx...
