    create new doc with SaveDocument
    4 Posts 0 Posters 462 Views
      On 23/02/2009 at 08:13, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      i want to save a single object into a new document, using this code:
      > <code>
      > fn.SetDirectory(Filename(path));
      > fn.SetFile(object->GetName());
      > fn.SetSuffix("c4d");
      > //GePrint("saving "+object->GetName()+" to "+fn.GetFileString());
      > AutoAlloc<BaseDocument> saveDoc;
      > BaseObject* clone = (BaseObject* )object->GetClone(COPY_NO_ANIMATION,NULL);
      >                saveDoc->InsertObject(clone,NULL,NULL);
      >                saveDoc->SetDocumentName(fn.GetFileString());
      > fn.FileSelect(FSTYPE_SCENES, GE_SAVE);
      >           if(SaveDocument(saveDoc,fn,SAVEFLAG_SHOWERROR, FORMAT_C4DEXPORT)) {
      >      GePrint("TRUE - SUCCESS");
      > else {
      >      GePrint("FALSE - FAILED");
      > </code>
      i get the 'save as' dialog, but when i press 'save', it always returns false.. Does anybody know what is wrong with the code ?
      thanks,
      Daniel
        On 23/02/2009 at 08:40, xxxxxxxx wrote:
        I'd drop the 'fn.FileSelect()' call altogether. This is accomodated in the SaveDocument() call:
        SaveDocument(saveDoc, fn, SAVEFLAG_SHOWERROR|SAVEFLAG_SAVEAS, FORMAT_C4DEXPORT)
        It may be that 'saveDoc' must be inserted into the document list before it can be saved. Have you tried InsertBaseDocument(saveDoc) before saving? Since you AutoAlloc the BaseDocument, I would remove it from the document list right after saving with saveDoc->Remove(); to avoid crashing.
          On 23/02/2009 at 09:43, xxxxxxxx wrote:
          lol, i got it now..
          was using an older demo-version of c4d for backward-compatibility, thus saving was disabled ofc .. 😉
          thanks for trying to help me robert, now it works with the original code.
          Daniel
            On 23/02/2009 at 10:11, xxxxxxxx wrote:
            Ah. Yeah, you can't save documents from a demo-version.
            Glad you got around that. 🙂
