    include every file in directory
    4 Posts 0 Posters 384 Views
      On 15/02/2009 at 06:29, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Platform:    Mac  ;
      Does anyone know a way to include every file in a directory into the .cof-file whithout knowing the filenames?
      Thanks in advance for your help,
      Gambetti
        On 15/02/2009 at 08:34, xxxxxxxx wrote:
        What kind of files? Into the same folder as the .cof file?
        Or into the cof code?
        As long as you know where they are I suppose -maybe-
        there should be some way but I'm not sure.
        I think the include"file" function need the files placed and named
        beforehand.
        Other than that you might be able to at least read from files within
        the code.
        file->Open(fn, GE_READ); etc
        Lennart
          On 15/02/2009 at 15:34, xxxxxxxx wrote:
          I have a directory which might contain user-generated files (like "userClass.coh") with class-declarations. I want to include those files in the header of the .cof-file on startup.
          So, normally i would have
          > \> include 'userClass.coh'; \>
          in the header, but I don't know the name yet. - This doesn't seem to work with "file->Open". And it doesn't seem to be possible to have those include-statements wrapped inside a method. - So, probably there's no solution for this.
          Gambetti
            On 16/02/2009 at 02:06, xxxxxxxx wrote:
            This is not possible in COFFEE. One possibility would be to write a C++ plugin which modifies the sources of the COFFEE files upon starting Cinema4D.
