    VPBuffer GetLine / SetLine Dithering
    3 Posts 0 Posters 334 Views
      On 01/02/2009 at 21:24, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Platform:    Mac  ;
      Language(s) :
      24 bit dithering is turned off in render preferences.
      Using GetLine / SetLine with dithering flag set to false.
      Why would C4D still dither using a videop[ost plugin when rendering to 8bpc? It does noth dither if I remove the videopost plugin.
      The dithering goes away with 16bpc ( or i assume the precision is great enough to become indistinguishable ).
      thanks,
      David Farmer
      coreaudiovisual
        On 02/02/2009 at 03:28, xxxxxxxx wrote:
        Sorry Ican't confirm, it seems to work fine here. Can you describe your test setup please?
          On 02/02/2009 at 08:18, xxxxxxxx wrote:
          Everything works as expected unless I use GetLine / SetLine. When the pixel data is altered the pixels are dithered when they are put back. The client is rendering 16bpc so it isn't a huge problem for this production.
          Could be an issue in the future so I will test it against 11 when it arrives. If it is a problem I will publish an example illustrating the problem.
