    Bug in R11?
    6 Posts 0 Posters 654 Views
      On 26/01/2009 at 08:38, xxxxxxxx wrote:
      Cinema 4D Version:   11
      Platform:    Mac  ;
      Hi!
      I found out that this code crashes on Mac.
      Can anyone confirm? For a small workaround I put all the deallocation stuff
      into PluginMessage with the ID C4DPL_ENDACTIVITY which seems to work there.
      #include "c4d.h"
      BaseObject *op;
      Bool PluginStart(void)
           op = BaseObject::Alloc(Ocube);
      void PluginEnd(void)
           BaseObject::Free(op); //crashes here
      Bool PluginMessage(LONG id, void *data)
      Thanks and bye 🙂
        On 26/01/2009 at 09:10, xxxxxxxx wrote:
        Is 'op' ever inserted into a BaseDocument?
        Also, I wouldn't trust using global variables except under specific circumstances. Do a forum search for __WINCRTINIT.
          On 26/01/2009 at 10:03, xxxxxxxx wrote:
          Hi!
          Yes, you are right, it was just an example. I don't use global variables here. It was just an example to show that it crashes, when I free a GeListeNode object.
            On 29/01/2009 at 06:05, xxxxxxxx wrote:
            can anyone confirm that? thx 🙂
              On 29/01/2009 at 08:14, xxxxxxxx wrote:
              I can confirm this.
              You have to use C4DPL_ENDACTIVITY and C4DPL_STARTACTIVITY for allcoations/deallocations which depend on other plugins.
              You allocate a BaseObject (a cube) which is probably just another plugin by itself.
              Besides this the use of global static classes is forbidden (not your case since it's just a pointer).
              From the techinfo paper:
              Stability and Testing
              • Crashes due to use of global static classes
              • Crashes happen randomly and are often hard to reproduce
              • Allowed are elementary datatypes and datatypes that don't need to be allocated (LONG, Real, CHAR, GE_SPINLOCK etc.)
              • Any other SDK datatype cannot be placed in the global scope
              Wrong!
              AutoAlloc <String> my_global_string1;
              Stringmy_global_string2;
              Filenamemy_global_filename;
                On 06/03/2009 at 02:15, xxxxxxxx wrote:
                Hi!
                At first I checked out several cases and thought the object is not owned by my plugin but thats not the case.
                In PluginEnd I deallocate and clean up some allocated objects(BaseDocuments, BaseObjects, etc.) which were created in the sandbox. Well, I would do all that in C4DPL_ENDACTIVITY but thats not possible. So imagine the following case:
                Someone creates an object of BaseDocument in the sandbox. The sandbox is similar to the standard console and is just a terminal. So if you type
                doc = get_active_document.get_clone() you get a clone of the document which is stored in the sandbox and the object is alive until the sandbox is closed and freed which happens in PluginEnd().
                gDelete(glob->sandbox); the deconstructor cleans up all allocated objects. So imagine there is a BaseDocument like the example above so Py4D calls BaseDocument::Free(objectA); which crashs on Mac OSX but not on Windows. Interesting point: BaseBitmap::Free(objectB); does not crash in PluginEnd().
                So I set a global flag called "finalize" that BaseDocument::Free() will not be executed, if this is called from the cleanup management in PluginEnd. That means, there are memory leaks on Mac OSX. Is there another workaround?
                bye...
