    Conditions for execution; boolean
    11 Posts 0 Posters 1.1k Views
      On 19/01/2009 at 00:50, xxxxxxxx wrote:
      hi, if id==IDC_TYPE then IDC_TYPE==IDC_SELECT???. Maybe thats not what you want, is it?
      Bye.
        On 19/01/2009 at 00:58, xxxxxxxx wrote:
        shawni,
        no. here is a clearer scenario:
        -->click on checkbox
        -->click on button
        -->only then execute next line of code
        the line of code should be executed ONLY when both the checkbox AND button have been (checked/clicked)
          On 19/01/2009 at 02:19, xxxxxxxx wrote:
          Where are you checking for the IDC_SELECT button? Remember that a button has no state. It just triggers a message.
            On 19/01/2009 at 03:16, xxxxxxxx wrote:
            understood. but isn't the button action recorded, detected? So, i thought that if one clicks on a button, that must be TRUE or something like that. you're saying it is not.
            so, if i want the ability for someone to be able to select items using checkboxes then click on a button that executes the items of the checkboxes, what does one use?
              On 19/01/2009 at 03:47, xxxxxxxx wrote:
              You simply catch the button click in the dialogs Command() method.
              Somthing like this:
              > \> Bool MyDialog::Command(LONG id, const BaseContainer &msg;) \> { \>      if(id == IDC_SELECT) \>      { \>           GePrint("button"); \>      } \> \>      return TRUE; \> } \>
                On 19/01/2009 at 04:13, xxxxxxxx wrote:
                matthias,
                i understand, but i think i'm not making myself clear enough. the above example shows how to get code to execute by clicking the button. what i want to know is how to get it to execute ONLY the code that corresponds to a selected menu item or checkbox item.
                does that make any sense?
                STEP 1: I click on the checkbox next to the item "Apples"
                STEP 2: I then click on the button labeled "Create"
                after clicking on the button, an apple is created...
                which leads to my next scenario:
                I have 3 items with a checkbox next to each...
                Apples
                Bananas
                Grapes
                I check all of the items. I would then like to click on the "Create" button to create all of the items selected. How do I create such a mechanism?
                  On 19/01/2009 at 04:39, xxxxxxxx wrote:
                  Same thing, you check for your button in Command() and if any of the checkboxes has been checked. If so you create your items.
                  Example:
                  > \> Bool MyDialog::Command(LONG id, const BaseContainer &msg;) \> { \>      if(id == IDC_SELECT) \>      { \>           Bool chkbox; \> \>           if(GetBool(IDC_APPLE, chkbox) && chkbox) \>           { \>                //do something \>                GePrint("create apple"); \>           } \>      } \> \>      return TRUE; \> } \>
                    On 19/01/2009 at 05:41, xxxxxxxx wrote:
                    matthias,
                    thank you again! this is exciting!
                      On 19/01/2009 at 08:02, xxxxxxxx wrote:
                      Howdy,
                      Just to clarify why your line of code:
                      > if(id==IDC_TYPE && id==IDC_SELECT)
                      ... will always return FALSE, is that "id" is a single variable with a single value, and assuming that both IDC_TYPE and IDC_SELECT are members of an enumeration and have different constant values, "id" could only equal IDC_TYPE or it could only equal IDC_SELECT, but it couldn't equal both. ;o)
                      Adios,
                      Cactus Dan
                        On 19/01/2009 at 08:16, xxxxxxxx wrote:
                        CD,
                        understood. it makes sense...
