    Init method not run in 10.5
    4 Posts 0 Posters 578 Views
      On 26/12/2008 at 06:41, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Platform:      Mac OSX  ;
      Is there a difference between the 9.1 and the 10.5 COFFEE kit? My plugins run correct in 9.1 but not in 10.5.
      It seams that the Init routine doesn't get called in 10.5.
      > <code>fastCheck_gui::Init() {
      >      texture = 1;                                                  // default: B&W; texture
      >      scale = 100;                                                  // default: size of the texture
      >      material_name = "FastCheckMaterial";                    // default: name of the material
      >      SetInt(IDC_SLIDER, scale, 0, 100, 1);                    // initialize the slider
      >      println("INIT");
      >      arr = new(array, 17);
      >      arr[0] = 5159;      arr[1] = 5160;      arr[2] = 5162;      arr[3] = 5170;      arr[4] = 5174;      arr[5] = 5168;      arr[6] = 5164;
      >      arr[7] = 5167;      arr[8] = 5171;      arr[9] = 5172;      arr[10] = 5161; arr[11] = 5163; arr[12] = 5165; arr[13] = 5169;
      >      arr[14] = 5166; arr[15] = 5173; arr[16] = 5100;
      >      println(arr[2]);
      > }</code>
        On 27/12/2008 at 08:08, xxxxxxxx wrote:
        My bad! I docked the plugin to the interface and this doesn't trigger the Init() method. Starting from the plugin menu does! How can I run the Init() if the window is docked to the interface?
        The plugin is an instance of GeDialog.
          On 27/12/2008 at 10:53, xxxxxxxx wrote:
          You'll have to call the function yourself. I'm not sure if there is a message sent on docking, but maybe a BFM_LAYOUT_CHANGED or similar sent to Message(). You'll have to see what messages (if any) are sent upon docking and undocking.
            On 30/12/2008 at 06:08, xxxxxxxx wrote:
            The plugin is already docked to the interface when Cinema is started. And this doesn't trigger the Init() routine.
