    restore selection from edgeSelTag
    8 Posts 0 Posters 906 Views
      On 22/12/2008 at 08:43, xxxxxxxx wrote:
      Cinema 4D Version:   9.1+
      i have an edgeSelectionTag and I want to restore the edge selection on the object, that the tag belongs to.
      I cannot find any info on this, but maybe im not looking in the right spot..
      can somebody hint me in the right direction?
      thanks,
      Daniel
        On 22/12/2008 at 08:56, xxxxxxxx wrote:
        SelectionTag::GetBaseSelect() returns the selection stored in the tag.
          On 22/12/2008 at 09:17, xxxxxxxx wrote:
          thanks, but how would i use it to select the edges that are stored in the tag?
          i tried it like this, but it doesnt seem to be the right way to do it:
          > <code>
          > // deselect all
          > ToPoly(edges->GetObject())->GetEdgeS()->DeselectAll();
          > // restore selection from tag
          > BaseSelect* bs = edges->GetBaseSelect();
          > LONG seg=0,a,b,i;
          > while (bs->GetRange(seg++,&a;,&b;)){
          >     for (i=a; i<=b; ++i){
          >      bs->Select(i);
          > </code>
            On 22/12/2008 at 09:34, xxxxxxxx wrote:
            ok i tried it differently now, using setSelectedEdges().
            It does select some edges now, but not the right ones.
            Looks like its using the wrong edge indices..
            > <code>
            > PolygonObject* polyObj = ToPoly(edges->GetObject());
            >      // deselect all
            >      polyObj->GetEdgeS()->DeselectAll();
            >      Neighbor* ne = new Neighbor();
            >      ne->Init(polyObj->GetPointCount(), polyObj->GetPolygon(), polyObj->GetPolygonCount(), NULL);
            >      polyObj->SetSelectedEdges(ne,edges->GetBaseSelect(),EDGES_SELECTION);
            >      ne->Flush();
            > </code>
              On 22/12/2008 at 10:22, xxxxxxxx wrote:
              looks like sth is wrong with the baseSelect.
              > <code>
              > SelectionTag* edges = (SelectionTag* ) op->GetDataInstance()->GetLink(ES_EDGE_LINK,op->GetDocument());
              > </code>
              The link-field accepts 'Tedgeselection'.
              if i create the baseselect like this it works:
              > <code>
              > bs = polyObj->GetSelectedEdges(ne,EDGES_SELECTION);
              > </code>
              but i dont want the current selection, i want the selection that is stored in the edgeSelectionTag..
                On 23/12/2008 at 11:45, xxxxxxxx wrote:
                Howdy,
                For Cinema 4D's Edge Selection tag, an easy way would be to simulate clicking the "Restore Selection" button by sending a message to the tag like this:
                > \> DescriptionCommand dc; \> dc.id = DescID(EDGESELECTIONTAG_COMMAND1); \> edgSelTag->Message(MSG_DESCRIPTION_COMMAND,&dc;); \>
                Adios,
                Cactus Dan
                  On 28/12/2008 at 09:49, xxxxxxxx wrote:
                  Thanks Dan,
                  thats indeed how i did it now (found a code snippet in some old post).
                  Still i wonder what was wrong in the code above.
                  If i ever find out i'll add the solution here.
                  greetings,
                  Daniel
                    On 06/01/2009 at 00:28, xxxxxxxx wrote:
                    The selected edges in the Selection tag are encoded like this:
                    (4*poly)+edge, where edge goes from 0-3
                    Here an example that prints the poly and edge indices of a Selection tag:
                    > \> Bool MenuTest::Execute(BaseDocument \*doc) \> { \>      BaseObject \*op = NULL; \>      op = doc->GetActiveObject(); \>      if(!op) return TRUE; \> \>      if(op->GetType() == Opolygon) \>      { \>           SelectionTag \*tag = NULL; \>           tag = (SelectionTag\* )op->GetTag(Tedgeselection, 0); \> \>           if(tag) \>           { \>                BaseSelect \*sel = NULL; \>                sel = tag->GetBaseSelect(); \>                if(sel) \>                { \>                     LONG seg=0,a,b,i; \> \>                     while (sel->GetRange(seg++,&a;,&b;)) \>                     { \>                          for (i=a; i<=b; ++i) \>                          { \>                               LONG polyindex = i/4; \>                               LONG edgeindex = Mod(i,4); \> \>                               GePrint("poly index "+LongToString(polyindex)); \>                               GePrint("edge index "+LongToString(edgeindex)); \>                          } \>                     } \>                } \>           } \>      } \> \>      return TRUE; \> } \>
