    Deformer and Switching Views
    2 Posts 0 Posters 195 Views
      On 26/11/2008 at 13:13, xxxxxxxx wrote:
      Cinema 4D Version:   10.506
      Hi Guys,
      I'm running into a weird issue with my deformer plugin. I have setup a function that takes the point object of a deformer and calculates the vertex normal for each point of the object. So this function returns a Vector* array containing the normals of all points. Everything works fine with this function, I am able to deform off of the vertex normal direction. I call this function from within ObjectData::ModifyObject() using the provided BaseObject *op parameter.
      However, if I switch views in the editor (i.e. perspective to top) and the object I am deforming is a primitive the vertex normals are lost. But, if prior to switching the editor view I convert the primitive to a point object everything behaves fine after switching views.
      Thanks in advance,
      Josh
        On 27/11/2008 at 00:14, xxxxxxxx wrote:
        Without any code it is hard to tell what could be the problem.
