    Get info if 32bit or 64bit is running
    7 Posts 0 Posters 688 Views
      On 26/11/2008 at 01:02, xxxxxxxx wrote:
      Cinema 4D Version:   R9.6+
      Platform:   Windows  ; Mac  ;
      how can one determine whether the 32bit or 64bit version of C4D is currently running?
      Thanks in advance,
      Andre
        On 26/11/2008 at 12:34, xxxxxxxx wrote:
        Sorry but I don´t quite see what you mean. If the user is running the 64-Bit version of c4d when your plugin is running, this will only work if your plugin is 64-bit too. I don´t see the sense in your question. What are you trying to achieve or what do you have in mind?
          On 26/11/2008 at 16:01, xxxxxxxx wrote:
          Hiho...
          3D Designer, when he develops a plugin for windows, you're right because he has to develop two different version (cdl and cdl64)
          But whats on Mac, there is only one file for both versions.
          Mailard: Sorry, I don't know too but that would a very useful function I searched too.
          bye..
            On 26/11/2008 at 17:26, xxxxxxxx wrote:
            Although this is true for the MacOS dylib for R11, it still doesn't load all of the included versions - just the appropriate one. What the linker does in Xcode is to create a multi-lib file (there are ppc/intel/ppc64/intel-64 libs). Only the lib relevant to the processor and app mode (32/64) is loaded and registered by Cinema 4D.
            But as you say, it would be nice to be able to get both the OS (which can be done: GeGetCurrentOS()), the cpu type (which can be done: GeGetByteOrder()), and the bit size (32/64) (which cannot be done directly). GetSystemEnvironmentalVariable() may be useful indirectly (?).
              On 27/11/2008 at 02:36, xxxxxxxx wrote:
              exactly, something like that would be the thing I'd search for too. I did not achieve anything with GetSystemEnvironmentalVariable() thus far either though.
                On 27/11/2008 at 07:06, xxxxxxxx wrote:
                Check for the __C4D_64BIT define.
                Something like this:
                > \> #ifdef \__C4D_64BIT \>      GePrint("64 bit"); \> #else \>      GePrint("32 bit"); \> #endif \>
                  On 04/12/2008 at 10:37, xxxxxxxx wrote:
                  Thank you a lot!
