    Bug? TYPE_LOAD called after new material
    4 Posts 0 Posters 361 Views
      On 17/11/2008 at 11:32, xxxxxxxx wrote:
      Cinema 4D Version:   10.5, 11
      Using a SceneHook I found that when a new material is created, MSG_DOCUMENTINFO_TYPE_MATERIAL_INSERT is called as expected.
      But also, directly after that, MSG_DOCUMENTINFO_TYPE_LOAD is called. I thought MSG_DOCUMENT_TYPE_LOAD should only be called after loading a new C4D- document!
      Can anyone confirm that this a bug in C4D? Our plugin relies on some operations after loading a new document, but now gets confused after new materials are created.
      best regards,
      mcduck
        On 18/11/2008 at 02:07, xxxxxxxx wrote:
        I think MSG_DOCUMENTINFO_TYPE_LOAD is called because of the material preview which loads a document.
          On 18/11/2008 at 03:27, xxxxxxxx wrote:
          I can add that this unexpected MSG_DOCUMENTINFO_TYPE_LOAD is only called at inserting the first new material.
          Any following material or texture loading, will not cause a MSG_DOCUMENTINFO_TYPE_LOAD.
          (Just a MSG_DOCUMENTINFO_TYPE_MATERIAL_INSERT, as it should be)
          Are you sure that MSG_DOCUMENTINFO_TYPE_LOAD isn't just meant for c4d -documents (and not any other type of file/document loaded) ?
          If not, then could you point to a reliable way to run code when a c4d-document is loaded?
          regards,
          mcduck
            On 19/11/2008 at 06:56, xxxxxxxx wrote:
            Howdy,
            Poll for the message MSG_MULTI_DOCUMENTIMPORTED to run code only when the document is loaded. ;o)
            Adios,
            Cactus Dan
