    DrawPolygonObject() w/Transparency
    17 Posts 0 Posters 1.6k Views
      On 11/11/2008 at 11:48, xxxxxxxx wrote:
      Neither is creating normals (vn) in the exported .obj file. I am using a pre-release version of Riptide Pro though (haven't gotten around to getting the update and serial number). Maybe I'll get that updated and try again.
        On 11/11/2008 at 12:08, xxxxxxxx wrote:
        Ahh (odd).  Anyway, I just double-checked and the release version of Riptide Pro does indeed create Normal records ('vn') with just a Phong Tag - just send me your latest digits and I'll get you a license.
        Riptide (Classic) would also create Normal records, IF the mesh has a Normal Tag, which can be created using my Add Normals plugin (there never was a way to create a Normal Tag using the C4D interface - that's why I wrote Add Normals).
          On 11/11/2008 at 12:21, xxxxxxxx wrote:
          BTW, instead of the above, maybe try setting xray mode:
                ObjectColorProperties objColor;
                objColor.usecolor = ID_BASEOBJECT_USECOLOR_ALWAYS;
                objColor.xray = TRUE;
                m_MagZone->SetColorProperties(&objColor);
          ...I was using that on a separate object, but maybe your plugin can set it on itself?
            On 11/11/2008 at 12:37, xxxxxxxx wrote:
            Got the export working (as you already know). 🙂
            Plugin objects don't support X-Ray mode - it is not included in the Basic Properties. So, I'd be right back where I started - how to set transparency with BaseDraw. 😉
            Unfortunately, how even X-Ray is done isn't explained anywhere.
              Hmm... add a "C++ SDK - Rounded Tube" to your scene... it has an X-Ray option in it's Basic properties.
                On 12/11/2008 at 08:44, xxxxxxxx wrote:
                Actually, I just tried this in the Rounded Tube  example...
                    Bool RoundedTube::Message(GeListNode *node, LONG type, void *t_data)
                        if (type==MSG_DESCRIPTION_VALIDATE)
                            BaseContainer *data = ((BaseObject* )node)->GetDataInstance();
                            CutReal(*data,TUBEOBJECT_IRADX,0.0,data->GetReal(TUBEOBJECT_RAD));
                            CutReal(*data,TUBEOBJECT_ROUNDRAD,0.0,data->GetReal(TUBEOBJECT_IRADX));
                        else if (type==MSG_MENUPREPARE)
                            ((BaseObject* )node)->SetPhong(TRUE,FALSE,0.0);
                            //****  insert this code, below *****
                            ((BaseObject* )node)->SetColorProperties(&objColor);
                ..worked like a champ.
                  On 12/11/2008 at 08:48, xxxxxxxx wrote:
                  Hmm.. that was a generator object though... deformer objects don't have the X-Ray option - as you mentioned.
                    On 13/11/2008 at 05:39, xxxxxxxx wrote:
                    You could also calculate the vertex normals from the mesh yourself.
                      On 13/11/2008 at 17:09, xxxxxxxx wrote:
                      Or, I could use PolygonObject::CreatePhongNormals(). 🙂
                      Except that changing the values on the added/required Phong tag doesn't seem to change the display results of BaseDraw::DrawPoly() - always as if Angle Limit is off or Phong Angle is 180d even though I'm setting the values. It would sort of suck if I have to load the real object from file, get this Vector array, and write it out to file to use those values instead.
                      Luckily, DrawPoly() is responding to BaseDraw::SetTransparency().
                        On 14/11/2008 at 00:10, xxxxxxxx wrote:
                        What I'm doing is just using the polygon normal for the vertex normals - about all I need as this is a display representation and not a 'real' object. The results are facetted but at least not overly smoothed on the other end of the spectrum. Now onto more important parts of the code. 🙂
                          On 14/11/2008 at 06:23, xxxxxxxx wrote:
                          Just for future reference - and something I only recently discovered - calling ie.
                          op->SetPhong(true, true, Rad(80.0));
                          ... will create/add a Phong Tag on your mesh.   I used to always manually MakeTag() (or Alloc and Add) and then call SetPhong(), but that was apparently redundant.
                          Also, op->CreatePhongNormals() should give you Normals once a Phong Tag is on your mesh.
                          That may or may not help you out in this case - I want to see the more important parts working, myself :).
