    Some Questions about BitmapButton
    4 Posts 0 Posters 461 Views
      On 29/10/2008 at 03:04, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      I am very sorry if this has been discussed at length, but I couldn't find the information using the search engine.
      I am trying to construct a toolbar like menu (like the main toolbar in C4D). Since I couldn't find any UI element to use I am guessing it has to be done with CustomGUI elements. BitmapButton looks like a candidate to me, but I just can't figure out how to use it correctly. I found some code snippets in the forums using AddCustomGui(), which works...but I am trying to add the buttons via a resource file. I inserted a BITMAPBUTTON ID {} field, which seems to be parsed without errors, but how do I access the buttons methods (SetImage() etc.?)...am I completely off track here?
      Are there other ways to generate a graphic style button menu in a plugin (besides from using a UserArea and just painting the buttons on there)?
      Many thanks
      Markus
        On 29/10/2008 at 04:23, xxxxxxxx wrote:
        I found some others posts that instructed to create a toolbar inside C4D and then load it inside the plugin using LoadFile...how to I get my plugin commands to show up in C4Ds palette manager though?
          On 29/10/2008 at 08:26, xxxxxxxx wrote:
          I finally found a way to display my BitmapButtons. They show fine and display a previously registered icon.
          Also they have the toggle and button states enabled, they create an event which I can see in Command(). How do I check and set the button's enabled status though? SetBool doesn't seem to work...
            On 03/11/2008 at 01:46, xxxxxxxx wrote:
            Please post some code otherwise I can't reproduce your problem.
