    Going down the list of objects...
    3 Posts 0 Posters 268 Views
      On 21/10/2008 at 21:57, xxxxxxxx wrote:
      Cinema 4D Version:   11
      Platform:      Mac OSX  ;
      As a beginner to COFFEE, I'm having trouble wrapping my head around the whole calling main() with each frame idea.
      With this example, I want to cause a set of objects to go from scale <A,A,A> to scale <B,B,B> every n frames, and one at a time.
      FRAME 0: OBJECT 1 CHANGES
      FRAME N: OBJECT 2 CHANGES
      FRAME N*2: OBJECT 3 CHANGES
      FRAME N*3: OBJECT 4 CHANGES
      As you can see, my code doesn't work.
      One big question is: what is the proper way to remember where in the list of objects I am from frame to frame (since, when main is called over and over, my pointer keeps getting sent back to the beginning)? The way I'm attempting to do this is to just start at the first object and renavigate my way down the list according to a count I'm keeping. But, besides being inelegant, it doesn't work.
      I'd be extremely appreciative if someone could point me in the right direction.
      The file
      is here , and the code follows below.
      Thanks!,
      Michael
      > var where = 0; \> var count = 0; \> main ( the_Document, the_Object ) \> \>      { \>      var cuber = the_Document->FindObject ( "First Cube" ); \> \>      //zap all cubes down to 0 scale at first frame \>      if (where == 0) \>           { \>                while (cuber) \>                     { \>                          cuber->SetScale ( vector (0.5, 0.5, 0.5 ) ); \>                          cuber = cuber->GetNext( ); \>                     } \>     \>      } \>       \>       \>      where++; \>      //reset to first cube \>      cuber = the_Document->FindObject ( "First Cube" );      \>      //every 30 frames \> if ((where % 30) == 0)      \>           { \>                count++; //counting how many times we've hit % 30, and thus, what cube we should be up to \>                println("where is ",where,""); \>                println("count is ",count,""); \>            \>                 \>                var i;      \>                //attemping to follow the list down to the current item by starting at the beginning and counting down \>                for (i = 0; i < count; i++); \>                     { \>                     println("i is ",i,""); //why is i always the same as count, and not counting up from 0 each time we hit % 30? \>                     cuber = cuber->GetNext( ); \>                }      \>            \>                if (cuber) \>                          { \>                               cuber->SetScale ( vector ( 1, 1, 1 ) );     //this only works once!      \>                          } \>           } \> \>      }
        On 21/10/2008 at 22:17, xxxxxxxx wrote:
        oops - looks like the scene file I posted doesn't have the above code in it. thisone does
          On 22/10/2008 at 09:16, xxxxxxxx wrote:
          fixed it:
          > var where = 0; \> var count = 0; \> var cuber; \> main ( the_Document, the_Object ) \> \>      { \> \>      //zap all cubes down to 0 scale at first frame \>      if (where == 0) \>           { \>                         cuber = the_Document->FindObject ( "First Cube" ); \>                      while (cuber) \>                 { \>                    cuber->SetScale ( vector (0.0, 0.0, 0.0 ) ); \>                    cuber = cuber->GetNext( ); \>                } \>                           \>                               //reset to first cube \>                         cuber = the_Document->FindObject ( "First Cube" );    \>                     } \>       \>       \>            where++;      \> \>           if ((where % 3) == 0)      \>           { \>              \>                      if (cuber) \>                 { \>                        cuber->SetScale ( vector ( 1, 1, 1 ) );        \>               } \>            \>                          cuber = cuber->GetNext( ); \>                          } \> \> }
