    Check if Directory is empty
    9 Posts 0 Posters 970 Views
      On 11/10/2008 at 15:32, xxxxxxxx wrote:
      Cinema 4D Version:   R11
      Getting the grips of adding, reading, deleting etc. files pretty well.
      As of R11, I'd like to add my licenses in the UserPrefs as suggested, in a folder.
      But, if there are now license files in this folder, I'd like to
      delete it as well.
      So what I can't figure out is how to check for an empty directory
      (Folder with no files in it on the disc).
      I can brows to this folder but then since I have no name to add
      to the path I'm stuck.
      Any pointers of how to do that?
      Lennart
        On 11/10/2008 at 16:03, xxxxxxxx wrote:
        Use the BrowseFiles class.
          On 11/10/2008 at 16:45, xxxxxxxx wrote:
          Hi Robert. Yup that is what I'm trying.....
          But I can't get a TRU or FALSE out of it as it seems..
          > \>         var bf = new(BrowseFiles); \>       var path = GeGetStartupWritePath(); \>       path->AddLast("MyFolder"); \>       bf->Init(path,FALSE); \>       var name = bf->GetName(); \>       if(name) \>       println("Name is ",name); \>
          Thing is this only prints the "Name is" part, the rest (var name)
          simply doesn't print anything, its blank(!?).
          So, I'm still a bit lost I'm afraid..
          There is the GetNext() option, but not "GetDown()" or GetIn() to
          "get into" the folder to check.
          Lennart
            On 11/10/2008 at 16:55, xxxxxxxx wrote:
            There is an example at the bottom of the BrowseFiles documentation:
            var path = GeStartupPath();
            while (bf->GetNext())
                if (bf->IsDir())
                  println("dir ",bf->GetName());
                else
                  println("file ",bf->GetName());
            bf->GetNext() gets the first then next files/folders under the folder set in bf->Init().
              On 11/10/2008 at 17:15, xxxxxxxx wrote:
              Ah, I used that example to start with and also got that "blank" print.
              Just tried this:
              > \> var bf   = new(BrowseFiles); \> var path = GeGetStartupWritePath(); \> path->AddLast("MyFolder"); \> bf->Init(path,FALSE); \> \> if(bf->GetNext() != FALSE) \> println("Something here!"); \> else \> println("Nope, emty"); \>
              And even if MyFolder was empty, it wasn't!
              There is a frigging hidden ".DS_Store" file there!
              So the BrowseFiles seems to work but what to do with hidden files?
              I'm on Mac, is there anything similar happening in Windows?
              Lennart
                On 11/10/2008 at 17:54, xxxxxxxx wrote:
                On that in COFFEE, I don't know. You may need to check for that particular file by name when you get a hit, ignore it and continue on.
                  On 11/10/2008 at 18:09, xxxxxxxx wrote:
                  Thanks Robert.
                  It looks as if I'm on the wrong track anyway....
                  Recreating the "MyFolder" (From Finder) so there is nothing in it,
                  even no .DS_Store file, I still get a "Something here!" using the code
                  above.
                  Maybe someone from Maxon have a tip after the weekend.
                  Cheers and thanks
                  Lennart
                    On 20/10/2008 at 05:44, xxxxxxxx wrote:
                    I can not confirm this. If I create an empty folder on OSX with Finder->New Folder it is empty for Cinema as well. My code:
                    > \> var path = new(Filename); \> if(!path->PathSelect("Select Path")) return; \> \> var bf = new(BrowseFiles); \> bf->Init(path,FALSE); \> \> if(bf->GetNext()) println("not empty"); \> else println("empty"); \>
                      On 20/10/2008 at 05:47, xxxxxxxx wrote:
                      Thanks Matthias. I got it working (and have learnt a lot about file handling the last couple of days because of making license files:) )
                      Sorry to not tell.
                      Lennart
