    Expression jumps back
    7 Posts 0 Posters 521 Views
      On 30/09/2008 at 22:55, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Platform:      Mac OSX  ;
      I have a tag plugin that sets the lokal Object Matrix during Execute() :
      > ... \> op->SetMl(NewObjectMat,TRUE); \> return EXECUTION_RESULT_OK;
      The expression works just fine in general.
      However, as soon as I deselect all objects, or select a tag, then the object jumps back to another state (initial?).
      Any idea what causes this behaviour? Do I have to commit the change in the Matrix somehow? Do I set the objcet matrix the wrong way, so it get's destoyed? NewObjectMat is created during execute from scratch.
      Thanks for any helpful pointers!
      Kabe
        On 01/10/2008 at 12:12, xxxxxxxx wrote:
        Hi Klaus,
        don't see anything wrong here. I think the problem is rather how you calculate the new matrix.
        Maybe it's also safer to calculate a global matrix and transform it to the object's local? Would be stupid, but you never know...
        Jack
          On 02/10/2008 at 10:52, xxxxxxxx wrote:
          Well, as already said... the calculation of the new matrix is correct, and the tag works just fine, as long as I don't deselect anything.
          I'm creating the Matrix with
          > Matrix NewObjectMat; \> \> ... \> \> NewObjectMat = MatrixRotY(d);
          It seems that MatrixRotY delivers only a temporary Matrix, that is destroyed as soon as any other proces is called.
          any advice?
          Kabe
            On 02/10/2008 at 11:15, xxxxxxxx wrote:
            > Quote: __
            > .. as long as I don't deselect anything.
            sounds like a check for doc- >getActiveObject() is not fulfilled anymore. do you do anything if nothing is selected somewhere in your code?
            your code above looks alright, i dont think there's much to be done wrong there..
            > Quote: __
            i dont think this is possible..
            maybe you have to do a MSG_UPDATE or sth, but thats just guessing on my side.
            greetings,
            Daniel
              On 02/10/2008 at 13:12, xxxxxxxx wrote:
              Npe, it's a tag plugin, there shouldn't be a need to signal an update.
              Kabe
                On 09/10/2008 at 07:55, xxxxxxxx wrote:
                Still struggling with this. Any further ideas would be appreciated. Kind of frustrating if a plugin works fine, but the results don't "stick"...
                Kabe
                  On 21/10/2008 at 07:21, xxxxxxxx wrote:
                  I can not confirm this. I may need some more detailed code. You can contact me through [email protected] if it is confidential data.
