    Line break in Messageboxes?
    11 Posts 0 Posters 1.1k Views
      On 23/09/2008 at 16:47, xxxxxxxx wrote:
      Cinema 4D Version:   10.1
      Platform:   Windows  ; Mac  ;
      I want to show a little text in a message box, using GeOutString(GeLoadString(MY_ID), GEMB_OK);
      Wonder if there's a possibility to get breaks into that text. \n does not work.
      Jack
        On 24/09/2008 at 05:33, xxxxxxxx wrote:
        \n should work.
        GeOutString(GeLoadString(MY_ID)+"\n", GEMB_OK)
        This does not work?
          On 24/09/2008 at 11:48, xxxxxxxx wrote:
          I've not seen it work on Mac but it does work on Windows.
            On 24/09/2008 at 15:07, xxxxxxxx wrote:
            No, it does not.
            When I put "\n" into the text, it just prints "\n" into the message box. It's not replaced by a line break 😞
            Well, it's not too dramatic. Would just have been nice.
            Greetings,
            Jack
              On 24/09/2008 at 15:34, xxxxxxxx wrote:
              Oh, yes it does! 😉
              At least up to R11 for sure. But I use MessageDialog(). Here is a line of code:
              MessageDialog(GeLoadString(IPPERR_EXISTFILE_TEXT)+"\n""+newFN.GetFileString()+""");
              On Windows, this prints as two lines in the dialog. Can't check this one in R11 since TreeView right-click context menus aren't working (darn - post to come). Maybe a difference between MessageDialog() and GeOutString() perhaps?
                On 27/09/2008 at 02:18, xxxxxxxx wrote:
                Hey, you are right!
                But it only works if I insert the "\n" in my Code. If the string loaded via GeLoadString() contains "\n" it's being ignored. Strange...
                Greetings,
                Jack
                  On 27/09/2008 at 10:55, xxxxxxxx wrote:
                  GeLoadString() might be stripping EOL characters (?). You could try the Unicode \uXXXX equivalent and see if that passes through unscathed. 🙂
                    On 19/04/2010 at 05:31, xxxxxxxx wrote:
                    I'm at exact the same issue right now, are there any news on this?
                    I'm loading error messages from resources. It works when using Windows CRLFs to separate lines, but I would consider this as an ugly hack:
                    MY_ERRORDLG_MESSAGE "This works in Mac and Windows
                    if divided with CR+LF but it's fugly";
                    The correct way would be to use the Unicode Line Separator (U+2028) like this:
                    MY_ERRORDLG_MESSAGE "This works in Mac\u2028but not on Windows!";
                    Ayn third option that I've overlooked?
                    Kabe
                      On 24/04/2010 at 06:59, xxxxxxxx wrote:
                      Howdy,
                      Have you tried using the "\u000D" for carriage return (CR)?
                      Adios,
                      Cactus Dan
                        On 26/04/2010 at 00:54, xxxxxxxx wrote:
                        No, I have not - as it's defined as legacy in Unicode.
                        It actually does work though, thanks.
                        Kabe
                          On 26/04/2010 at 05:35, xxxxxxxx wrote:
                          Please use the vertical bar sign "|" to seperate lines, for example "First Line|Second Line".
