LONG ULONG demoted to int in 64-bit?
On 13/09/2008 at 15:27, xxxxxxxx wrote:
Cinema 4D Version: R11
Platform: Mac OSX ;
Language(s) : C++ ;---------
This is causing me no end of grief. I thought it went like this:byte/char = 8-bits
word/short = 16-bits
long = 32-bits
long long = 64-bits
int = varies (but obviously not seen as long int here)So, now that you've redefined LONG as int and ULONG as unsigned int on Mac 64-bit, Xcode is warning and erroring on any LONG/ULONG used in circumstances where it expects a 32-bit value (GeData, %ld in <>printf() calls, etc.). I'm also getting 'note's about GeData static type setting "Line Location: c4d_gedata.h: <blah>"
Why did you do this? Any way to suppress the notes or should they just be ignored?
On 15/09/2008 at 08:35, xxxxxxxx wrote:
Quote: "This is causing me no end of grief. I thought it went like this:
> byte/char = 8-bits
> long = 32-bits
> long long = 64-bits
> * * *This assumption is false. On Windows you use the LLP64 bit model, on OS X and Linux you use the LP64 model.
Win64:
- pointers are 64 bit
- <int> and <long> are 32 bit
- <long long> is 64 bitOS X / Linux 64 bit:
- <int> is 32 bit
- <long> is 64 bitAnd that leads us to the source of your problem. the std C functions (like
printf) are expecting a 64 bit value on OS when using the "%ld" format string and a 32 bit value, when compiling on Win.This can introduce extremly hard to find bugs when using something like scanf(), because the input functions might expect 64 bit data (and that might get even worse when you are on PPC with different byte sex).
How to get around this mess:
1. Use proper format strings for printf/scanf (it has to be "%d" not "%ld")
2. Use Cinema's data types (like LONG)
3. Eventually use Cinema's data type VLONG/VULONGBest regards
Wilfried
On 15/09/2008 at 11:56, xxxxxxxx wrote:
At least somebody had the balls to respond.
1. That sucks. I use <x>printf because C4D API equivalents are notorious for bad float conversions (1.234 instead of 1.23456789, no exponential notation, etc.). I could break out the integer values using the C4D equivalents though and only use <x>printf for float values.
2. Always and everywhere. GeData(LONG) can't possibly be an issue with using other data types. The variables used are LONG to begin with.
> * * *Well it is fine to use it. I just want to make sure you know what you are doing (we spent an awful lot of time to hunt a (very old) bug inside of some interpreter code on PPC64 that - falsely - used %ld when it expected a 32 bit value and got 64 bit instead...).
Therefore I suggest: Read K&R; carefully and check your printf/scanf format strings!
Best regards,
Wilfried
On 15/09/2008 at 14:51, xxxxxxxx wrote:
I used K&R; to learn C (starting many years ago back in my Amiga days around 1989). And I've used Stroustrup for C++. K&R; and Stroustrup mention the 'l' specifier as a 'long int' for '%ld'. Included in the C99 specification is 'll' for 'long long int' for instance. I do realize that the size of these monikers (word, int, long) are not writ in stone and may change with system. Just bad that the connotation of 'ld' now means 64-bit in this one instance whereas 'lld' IS the actual appropriate choice here - as far as I'm concerned. I can never understand how Apple makes these decisions.
> I used K &R; to learn C (starting many years ago back in my Amiga days around 1989). And I've used Stroustrup for C++. K&R; and Stroustrup mention the 'l' specifier as a 'long int' for '%ld'. Included in the C99 specification is 'll' for 'long long int' for instance. I do realize that the size of these monikers (word, int, long) are not writ in stone and may change with system. Just bad that the connotation of 'ld' now means 64-bit in this one instance whereas 'lld' IS the actual appropriate choice here - as far as I'm concerned. I can never understand how Apple makes these decisions.
> * * *It is more or less MS's decision to use a different model. All Unix vendors choose the LP64 model (<long> 64 bit) - and that was a long time before MS created their first 64 bit system.
MS choose LLP64 (<long long> 64 bit) - I guess - because otherwise they would have killed COM and other 32 bit apis in 64 bit...
Best regards,
Wilfried
P.S. (as we are talking about stumbling blocks ) : If you are using C-runtime lib functions with wchar_t (like wmemset(), etc.) be aware of the different defintion on Windows and Unix systems. wchar_t is 16 bit on Win, but 32 bit on Unix systems.
