    How to access Quantize information?
    4 Posts 0 Posters 372 Views
      On 10/09/2008 at 14:53, xxxxxxxx wrote:
      Cinema 4D Version:   11
      Hi;
      how do I access the Quantize information programmatically? The AM shows it as part of the Move / Rotate / Scale tools (Snap settings -> Quantize), however, the tools share the same underlying values. What's the proper way to read and set those?
        On 14/09/2008 at 09:56, xxxxxxxx wrote:
        Hi again;
        no replies yet, so I searched through the sources textually. There seem to be no regular functions to access the Quantize information, but naturally I can look into the Description of the Tool dialog, which says
        BOOL SNAP_LOCAL_MOVEENABLE { }
        REAL SNAP_LOCAL_MOVE { UNIT METER; }
        Now, I naively assume that I could set these values in the BaseContainer they're in, and thereby change the information and the application's behavior. But where can I find this Container? For objects or tags, this is easy, but generally speaking:
        Where do I find the BaseContainers for built-in tools (and other objects that are not part of the object tree)?
        Seems I'm missing a rather large chunk of very basic information here... thanks in advance for any hint...
          On 22/09/2008 at 07:38, xxxxxxxx wrote:
          You have to use GetSettingsInstance() to obtain the snap settings container. Example:
          > \> Bool MenuTest::Execute(BaseDocument \*doc) \> { \>      StopAllThreads(); \> \>      BaseContainer \*bc = doc->GetSettingsInstance(SETTINGS_MODELER); \> \>      bc->SetBool(SNAP_LOCAL_MOVEENABLE, TRUE); \>      bc->SetReal(SNAP_LOCAL_MOVE, 100.0); \> \>      doc->Message(MSG_UPDATE); \> \>      EventAdd(); \> \>      return TRUE; \> } \>
            On 22/09/2008 at 14:44, xxxxxxxx wrote:
            Oops, so I was looking in the wrong containers... thanks for the info!
