    Help in Visual C ++2005 programming
    4 Posts 0 Posters 560 Views
      On 09/09/2008 at 03:45, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Language(s) :   C.O.F.F.E.E  ;  C++  ;
      Hi there ..
      i tried to create a cube object ...
      in coffee the code was :
      var cube1 = new(CubeObject);
      cube1->SetName("Object");
      GetActiveDocument()->InsertObject(cube1,NULL,NULL);
      but in VC++ error show up ..
      i take a look in the SDK i found this :
      static BaseObject* Alloc(ocube)
      VC++ gives errors on "ocube" and i'm sure it's right
      and this :
      BaseObject *GeneratePrimitive(BaseDocument *doc, LONG type, const BaseContainer &bc;, Real lod, Bool isoparm, BaseThread *bt)
      but i didn't know the exact parameters ..
      So help me please ..
        On 09/09/2008 at 03:55, xxxxxxxx wrote:
        I see two errors here.
        First in COFFEE you should use
        AllocObject(Ocube) and not new(CubeObject) anymore.
        Second it is Ocube and not ocube.
        In C++ it would be something like this
        > \> BaseObject \*cube = NULL; \> cube = BaseObject::Alloc(Ocube); \> if(!cube) return FALSE; \> \> doc- >InsertObject(cube, NULL, NULL); \>
        Please also check the SDK examples.
          On 09/09/2008 at 06:23, xxxxxxxx wrote:
          i tried your code and give me 2 errors :
          Error 1 error C2065: 'doc' : undeclared identifier
          Error 2 error C2227: left of '->InsertObject' must point to class/struct/union/generic type
          it works when i Define the doc :
          BaseDocument *doc = GetActiveDocument();
          BaseObject *cube = NULL;
          doc->InsertObject(cube, NULL, NULL);
          thanks Matthias ...
            On 09/09/2008 at 06:28, xxxxxxxx wrote:
            doc is the BaseDocument.
            Please check the SDK examples and the SDK documentation for a general introduction into the C++ plugin API.
