    Making Pluging First steps
    4 Posts 0 Posters 357 Views
      On 08/09/2008 at 08:53, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Language(s) :   C.O.F.F.E.E  ;  C++  ;
      Hi geys ..
      i have VC++ and i want to program a c4d plugin
      i searched the forum to know the first steps to it ..
      when i open the cinema4dsdk.dsw in VC++ .. But the _api_v8 file is missing ..
      any help to make my first plugin ?
        On 08/09/2008 at 09:14, xxxxxxxx wrote:
        Which version of VC++ are you using? For 10.5 you MUST use Visual Studio 2005 minimum and the .vcproj included.
        First step is to open the cinema4dsdk.vcproj in VS2005 and build the release and/or debug versions. This builds the api lib(s) you will need for your plugin projects and you should also verify that the cinema4dsdk plugin was properly created both in build and in Cinema 4D.
        After that, there are two directions you can go:
        1. Copy the cinema4dsdk.vcproj to your plugin project folder and modify it to suit your plugin (change sources, build name, and so forth). Realize that this will rebuild the api lib every build (blech).
        2. Do the same thing but remove the api build part of the project and, instead, include the already built api lib in the Libs folder of the project Solution Explorer. If you need both release and debug, you can include both api libs and exclude each one as needed (right-click over the lib in Solution Explorer, Properties, 'Exclude From Build').
          On 08/09/2008 at 09:47, xxxxxxxx wrote:
          thanks Robert.
          and yes i will do plugin for 10.5 .. and i have vs2005
          i will try it ...
          thanks again ..
            On 08/09/2008 at 12:46, xxxxxxxx wrote:
            oh my god ...
            Robert you are my hero ... i didn't think it will be easy like that ..
            now i will code my first plugin .. and i'm happy
            thanks bro ..
