    Create Material Filename Track
    5 Posts 0 Posters 413 Views
      On 01/09/2008 at 03:45, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      I am currently trying to set a material's Filename property by using a timeline Track. I successfully did this for object animation in C++ already. I can't seem to find the correct way to create the following Track:
      Material->Bitmap->File
      How do I create this track to change the Filename for specific frames? (I somehow don't seem to fully understand the correct use of DescID, DescLevel)
      Many thanks
      Markus
        On 01/09/2008 at 04:01, xxxxxxxx wrote:
        Here is how you access the filename of a texture in the color channel of a standard material.
        > \> Bool MenuTest::Execute(BaseDocument \*doc) \> { \>      BaseMaterial \*mat = NULL; \>      mat = doc->GetFirstMaterial(); \>      if(!mat) return TRUE; \> \>      BaseChannel \*ch = NULL; \>      ch = mat->GetChannel(CHANNEL_COLOR); \>      if(!ch) return TRUE; \> \>      PluginShader \*sh = NULL; \>      sh = ch->GetShader(); \>      if(!sh || sh->GetType()!=Xbitmap) return TRUE; \> \>      BaseContainer \*data = sh->GetDataInstance(); \> \>      Filename fn = data->GetFilename(BITMAPSHADER_FILENAME); \> \>      GePrint(fn.GetString()); \> \> \> \>      return TRUE; \> } \>
          On 01/09/2008 at 05:43, xxxxxxxx wrote:
          Hello Matthias,
          thanks for your quick answer.
          I already found an example like this, what I'd like to achieve though, is to create a CTrack which changes the Filename based on a certain Frame. I was able to create a Timeline track in Cinema 4D (Material->Bitmap->File) and change the filename manually inserting new keys. How do I replicate this behaviour in C++?
          I am tryint to create the CTrack but couldn't figure out how to access the Filename property. Furthermore SetValue only seems to work with "Real" values and there doesn't seem to be a SetString method for keys (although I seem to be able to insert "String"-keys using the Cinema 4D timeline interface.
          Many Thanks
          Markus
          edit:
          To clear up what I mean:
          In Cinema 4D I open the timeline, open the material (which displays Bitmap), right click on Bitmap, add property track->File. On this track I can create keys being strings that point to a specific file. This is the behaviour I am trying to duplicate in C++.
          edit2:
          have been trying this so far:
          > \>      CTrack\* texture_track; \>      CKey\* current_key = NULL; \> \>      current_key = CKey::Alloc(); \> \>      texture_track = CTrack::Alloc   (bg_material,   DescID(DescLevel(BASECHANNEL_TEXTURE,DTYPE_TEXTURE,0))); \> \>      current_key->SetTime(texture_track->GetCurve(),BaseTime(1, 30)); \>      current_key->SetGeData(texture_track->GetCurve(), GeData("Text")); \>      texture_track->GetCurve()->InsertKey(current_key); \>
            On 01/09/2008 at 07:54, xxxxxxxx wrote:
            This should work:
            > \>      BaseMaterial \*mat = NULL; \>      mat = doc->GetFirstMaterial(); \>      if(!mat) return TRUE; \> \>      BaseChannel \*ch = NULL; \>      ch = mat->GetChannel(CHANNEL_COLOR); \>      if(!ch) return TRUE; \> \>      PluginShader \*sh = NULL; \>      sh = ch->GetShader(); \>      if(!sh) \>      { \>           sh = PluginShader::Alloc(Xbitmap); \>           if(!sh) return FALSE; \>           BaseContainer \*data = mat->GetDataInstance(); \>           data->SetLink(MATERIAL_COLOR_SHADER, sh); \>           mat->InsertShader(sh, NULL); \>      } \> \>      else if(sh->GetType()!=Xbitmap) return TRUE; \> \>      CTrack \*track = NULL; \>      track = CTrack::Alloc(sh,DescLevel(BITMAPSHADER_FILENAME,DTYPE_FILENAME,0)); \>      if(!track) return FALSE; \> \>      sh->InsertTrackSorted(track); \> \>      BaseTime time = doc->GetTime(); \> \>      CKey \*key = NULL; \>      key = track->GetCurve()->AddKey(time); if (!key) return FALSE; \> \>      Filename fn("test.jpg"); \> \>      GeData data(fn); \> \>      key->SetGeData(track->GetCurve(), data); \>      key->SetInterpolation(track->GetCurve(), CINTER_STEP); \>
              On 01/09/2008 at 08:47, xxxxxxxx wrote:
              Many Thanks Matthias,
              getting the shader was what I was missing.
              Works like charm.
              Markus
