    about hypernurbs object
    7 Posts 0 Posters 617 Views
      On 31/08/2008 at 07:47, xxxxxxxx wrote:
      Cinema 4D Version:   10.1
      Hi, i have a question about generating a hypernurbs object with coffee.
      the following lines work for most objects, but not for the hypernurbs. why?
      var HN = AllocObject(Ohypernurbs);
      vDoc->InsertObject(HN,NULL,NULL);
      i already have another snippet, just like to know why the above code does not work?
        On 31/08/2008 at 15:22, xxxxxxxx wrote:
        Hi ello 🙂
        It looks like a bug - if you need a HyperNurbs in the active Document, use CallCommand().. that should do the same.
        Bye
          On 31/08/2008 at 15:44, xxxxxxxx wrote:
          Ohypernurbs is not used anymore. Use Osds instead.
            On 31/08/2008 at 16:59, xxxxxxxx wrote:
            Hi matthias 🙂
            Do you know the date release for the the new documentations?
            Thanks.
              On 01/09/2008 at 00:26, xxxxxxxx wrote:
              Quote: _Do you know the date release for the the new documentations?
              _
              Sorry, I can't say when. We are working hard to get it ready but it can take still some weeks.
                On 01/09/2008 at 11:08, xxxxxxxx wrote:
                thank you, matthias..
                  On 02/05/2009 at 15:51, xxxxxxxx wrote:
                  Ohypernurbs is still in the documentation, it would be cool if there would be a short info about to use Osds instead
