    Demo plugins need to now R11DEMO version
    10 Posts 0 Posters 871 Views
      On 28/08/2008 at 13:05, xxxxxxxx wrote:
      Cinema 4D Version:   R11 DEMO
      Hi.
      By Todays first update of R11 DEMO, the version is not longer
      the same as R10 DEMO.
      By printing out;
      var version = GeGetVersionType();
      I now get version 4739.
      Can we assume that this will be the version number of R11 DEMO,
      or will it change for each update.
      -And- will it change if the user register for a 42 save enabled version?
      Lennart
        On 01/09/2008 at 10:59, xxxxxxxx wrote:
        Any input on this, please.
        Lennart
          On 01/09/2008 at 11:58, xxxxxxxx wrote:
          Please check for VERSION_SAVABLEDEMO.
            On 01/09/2008 at 14:38, xxxxxxxx wrote:
            Just a little correction, please check for VERSION_SAVABLEDEMO and VERSION_SAVABLEDEMO_ACTIVE.
              On 01/09/2008 at 14:57, xxxxxxxx wrote:
              Thanks Matthias.
              So will:
              > if(GeGetVersionType()&VERSION;\_SAVABLEDEMO) \> println("VERSION_SAVABLEDEMO");
              be enough or will I need
              > if(GeGetVersionType()&VERSION;\_SAVABLEDEMO_ACTIVE) \> println("VERSION_SAVABLEDEMO_ACTIVE");
              ..as well for a activated DEMO? (The 42 days saveable one)
              Lennart
                On 01/09/2008 at 14:58, xxxxxxxx wrote:
                Ops, missed your last postbefore asking:)
                Lennart
                  On 04/09/2008 at 19:22, xxxxxxxx wrote:
                  So, do you just check like this?:
                  if (GeGetVersionType()&(VERSION_SAVABLEDEMO|VERSION_SAVABLEDEMO_ACTIVE)) ...
                  Thanks!
                    On 05/09/2008 at 02:05, xxxxxxxx wrote:
                    Atm, I run them separate, as in my post above as I wasn't sure about
                    using a "or" (single beam, " | ") inside a bitwise check:)
                    I'm also not sure how to make it work for R10 (within the same plugin)
                    as the "SAVABLEDEMO_ACTIVE" and "SAVABLEDEMO" are not defined in R10.
                    (I like to have the plugin to load in R10 and R11)
                    In pre R11 only "VERSION_DEMO" is defined.
                    Would the numeric values as seen below be safe enough?
                    > \> #define VERSION_CINEMA4D                              (1<<0) \> \> #define VERSION_BODYPAINT                              (1<<1) \> \> #define VERSION_NET                                        (1<<2) \> \> #define VERSION_SERVER                                   (1<<3) \> \> #define VERSION_DEMO                                        (1<<4) \> \> #define VERSION_BENCHMARK                              (1<<6) \> \> #define VERSION_BODYPAINT2_EX                    (1<<7) \> \> #define VERSION_MODELER                                   (1<<8) \> \> // 1<<9 somehow used in GeGetVersionTypeSDK \> \> #define VERSION_BPSTANDALONE                    (1<<10) \> \> #define VERSION_UPDATER                                   (1<<11) \> \> #define VERSION_SAVABLEDEMO                         (1<<12) \> \> #define VERSION_SAVABLEDEMO_ACTIVE     (1<<13) \>
                    Lennart
                      On 05/09/2008 at 08:36, xxxxxxxx wrote:
                      I use preprocessor directives to distinguish builds for different Cinema 4D versions (inclusive). So, for this, I'm doing this (is working!) :
                      >      BOOL     network =     FALSE; \>      LONG     vtype =          GeGetVersionType(); \>      if ((vtype & VERSION_SERVER) || (vtype & VERSION_NET))     network = TRUE; \> #ifdef     C4D_R11 \>      if (!((vtype & VERSION_DEMO) || (vtype & VERSION_SAVABLEDEMO|VERSION_SAVABLEDEMO_ACTIVE) || network)) \>      { \>           // serial number check \>           if (!(ippSerial && ippSerial->registered)) return FALSE; \>      } \> #else \>      if (!((vtype & VERSION_DEMO) || network)) \>      { \>           // serial number check \>           if (!(ippSerial && ippSerial->registered)) return FALSE; \>      } \> #endif
                        On 08/09/2008 at 02:24, xxxxxxxx wrote:
                        Quote: So, do you just check like this?:
                        > if (GeGetVersionType() & VERSION_SAVABLEDEMO|VERSION_SAVABLEDEMO_ACTIVE))
                        Yes, VERSION_SAVABLEDEMO is just the demo and VERSION_SAVABLEDEMO_ACTIVE is the activated demo.
