    Polygon Flow
    3 Posts 0 Posters 296 Views
      On 27/08/2008 at 12:58, xxxxxxxx wrote:
      Cinema 4D Version:   r10.1
         Hi, i am currently facing a problem with creating a proper polygonflow for an object. Generally it would help me if i could see how for example the "ebenen"-object is created with c.o.f.f.e.e.
      my current snippet is this, btw, the
      if (op#ID_USERDATA:1==1) is just a boole userdata to start the script:
      \>  main(doc,op)
      \>  var random = new(Random);
      \>  random->Init(time());
      \>       if (op#ID_USERDATA:1==1)
      \>            op#ID_USERDATA:1=0;
      \>            op#ID_USERDATA:2="Gestartet";
      \>            var newObj = new(PolygonObject);
      \>            newObj->SetName("terra");
      \>            doc->InsertObject(newObj,NULL,NULL);
      \>            GeEventAdd(DOCUMENT_CHANGED);
      \>            var vc = new(VariableChanged); if (!vc) return FALSE;
      \>            var cnt;
      \>            var ok;
      \>            var _xCnt,_yCnt,_xPos,_yPos,_vPos;
      \>            var _p1,_p2,_p3,_p4;
      \>            var _xMax = op#ID_USERDATA:3; var _yMax = op#ID_USERDATA:4;
      \>            var _pNum;
      \>            var pArr = new(array,_xMax*_yMax);
      \>            for (_xCnt=0;_xCnt<_xMax;_xCnt++)
      \>                 for (_yCnt=0;_yCnt<_yMax;_yCnt++)
      \>                      cnt = newObj->GetPointCount();
      \>                      vc->Init(cnt,cnt+1);
      \>                      ok =newObj->MultiMessage(MSG_POINTS_CHANGED,vc);
      \>                      _pNum = cnt;//_xCnt*_yMax + _yCnt;
      \>                      _xPos = (_xCnt-_xMax/2)*200;
      \>                      _yPos = (_yCnt-_yMax/2)*200;
      \>                      _vPos = 512*random->Get01();
      \>                      newObj->SetPoint(_pNum,vector(_xPos-100,_vPos,_yPos+100));
      \>            for(_xCnt=0;_xCnt<_xMax;_xCnt++)
      \>                 for(_yCnt=0;_yCnt<_yMax-1;_yCnt++)
      \>                      cnt = newObj->GetPolygonCount();
      \>                      ok =newObj->MultiMessage(MSG_POLYGONS_CHANGED,vc);
      \>                      _pNum = cnt;//_xCnt*_yMax + _yCnt;//
      \>                      _p1 = _pNum;
      \>                      _p2 = _pNum + 1;
      \>                      _p3 = _pNum + _yMax + 1;
      \>                      _p4 = _pNum + _yMax;
      \>                      newObj->SetPolygon(_pNum, _p1,_p2,_p3,_p4);
      \>            var t = AllocTag(Tphong);
      \>            newObj->InsertTag(t,NULL);
      \>            newObj->Message(MSG_UPDATE);
      \>            doc->SetActiveObject(newObj);
      \>            op#ID_USERDATA:2+="\nFertitsch";
      but it creates a big polygon when one row is finished and the other starts.
      it would be cool if someone points me to the solution
      thanks in advance,
      ello
        On 28/08/2008 at 01:44, xxxxxxxx wrote:
        here you go:
        > \> var x = 10; //x resolution \> var y = 10; //y resolution \> \> var op = doc->GetActiveObject(); \> \> if (!op || !instanceof(op,PolygonObject)) return; \> \> var vc = new(VariableChanged); if (!vc) return; \> \> var vcnt = op->GetPointCount(); \> vc->Init(vcnt, (x+1)\*(y+1)); \>        \> if(!op->MultiMessage(MSG_POINTS_CHANGED,vc)) return; \> println("points changed"); \> \> var fcnt = op->GetPolygonCount(); \> vc->Init(fcnt, x\*y); \> \> if(!op->MultiMessage(MSG_POLYGONS_CHANGED,vc)) return; \> println("polygons changed"); \> \> println("set points"); \> \> var i,j,k=0; \> for(i=0; i<(y+1); i++) \> { \>      for(j=0; j<(x+1); j++) \>      { \>           op->SetPoint(k,vector(j\*20,0,i\*20)); \>           k++; \>      } \> } \> \> k=0; \> for(i=0; i<y; i++) \> { \>      for(j=0; j<x; j++) \>      { \>           var poly = new(Polygon); \>           poly->a = j+(i\*(x+1)); \>           poly->b = j+(i\*(x+1))+x+1; \>           poly->c = j+(i\*(x+1))+x+2; \>           poly->d = j+(i\*(x+1))+1; \>           op->SetPolygon(k,poly); \>           k++; \>      } \> } \> \> op->Message(MSG_UPDATE); \>
          On 28/08/2008 at 02:04, xxxxxxxx wrote:
          thank you very,very much!
          best greetings,
          christian
