    Insert objects?
    3 Posts 0 Posters 299 Views
      On 22/08/2008 at 17:22, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      can anyone throw some light into the insertion of objects?
      For example: I want to insert an object under another in the current BaseDocument. What would you prefer? InsertUnder from GeListNode or InsertObject with the argument "parent" from the BaseDocument class? I can't see the difference.. what makes more sense?
      Thanks for your replies.
      bye 🙂
        On 23/08/2008 at 00:13, xxxxxxxx wrote:
        InsertUnder can be used to insert objects WITHOUT a document (for example in a generator or to make internal calculations etc). InsertObject requires a document in any case (as it is a member function of basedocument..).
        That´s the difference. 🙂
        Btw. I like the python environment idea. Keep that work up, it´s looking very good!
          On 23/08/2008 at 04:00, xxxxxxxx wrote:
          Hi! 🙂
          Okay, thank your for the advice.
          And the python-plugin: I hope it works very well on the other systems.
