    Selection Object
    3 Posts 0 Posters 314 Views
      On 21/08/2008 at 20:59, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Platform:    Mac  ;
      Is it possible to restore the selection of a selection object in coffee? Ultimately, I'm trying to select a set of joints and then use the Align command. I figured it would be easier to use the selection object to pre-bundle the joints. If it's not possible to perform the restore selection, how would one go about selecting a set of objects?
        On 22/08/2008 at 01:42, xxxxxxxx wrote:
        You have to set the BIT_AOBJ bit. See following script, it selects all objects of a document.
        > \> StepThru(op) \> { \>      while(op) \>      { \>           op->SetBit(BIT_AOBJ); \>           StepThru(op->GetNext()); \>           op = op->GetDown(); \>      } \> } \> \> main(doc, op) \> { \>      StepThru(doc->GetFirstObject()); \> } \>
          On 22/08/2008 at 17:31, xxxxxxxx wrote:
          Thank you very much Matthias, that works perfectly.
