    SplineObject Problem
    5 Posts 0 Posters 443 Views
      On 31/07/2008 at 02:16, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Hi!
      I've a problem with the SplineObject. I create a spline and try to get the segments.
      GetSegmentCount() returns 0.. why? When I create two "splines" in one object it returns 2.. Does anyone know?
      thanks..
        On 31/07/2008 at 02:44, xxxxxxxx wrote:
        that´s simply the way it is. When it returns 0 it should actually return 1. It means nothing, don´t care. 🙂 (you should however check if there is at least 1 vertex in it...just to be sure 0 means 1).
        0+0 ergibt bei Cinema manchmal 1. ;-D
          On 31/07/2008 at 04:00, xxxxxxxx wrote:
          Hi 3DDesigner..
          In c4d 0+0 is 1(sometimes?) I am happy to see, that my plugin is in a good environment.. hehe.
          I wrapped this function for my python plugi, so I will fix this issue that get_segment_count() will return 1 on "0".
          Danke 🙂
            On 31/07/2008 at 05:57, xxxxxxxx wrote:
            If you have a segment count of zero the spline object has no segment tag yet. Check the VariableTag in the docu and also this thread (it applies to C++ and COFFEE)
            spline segments
              On 31/07/2008 at 07:39, xxxxxxxx wrote:
              Hi!
              I have to take my hat off to you.. Thank you for the info.
              bye..
