    GeDialog commands (source them out)
    SDK Help
    0
    • H
      On 15/07/2008 at 01:32, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
         Hi!
      I have a problem with the GeDialog. Can I source out some commands?
      For example
      \>  class myGUI : public GeDialog
      \>  public:
      \>      void createLayout()
      \>          create_my_own_gui();
      \>  void create_my_own_gui()
      \>  AddStaticText(....);
      In this case, my compiler reports "Cannot use AddStaticText without an object."
      What can I do? Thanks 🙂
      • H
        On 15/07/2008 at 02:11, xxxxxxxx wrote:
        AddStaticText() is a memberfunction of the class GeDialog, so your new function create_my_own_gui() should be a member of your derived class myGUI.
        • H
          On 15/07/2008 at 02:12, xxxxxxxx wrote:
          Hi! 🙂
          Yes, you're right, the problem is, I have to source the memberfunctions out of the hole class... 😕
          • H
            On 15/07/2008 at 02:26, xxxxxxxx wrote:
            You could try declaring create_my_own_gui() as a friend in your class myGUI, then it should have access to its members, not sure if it will work though:
                friend void create_my_own_gui();
            void createLayout()
            If it doesnt work, try something like:
            (function still declared as a friend)
            myGUI test;
            test.AddStaticText(....);
            • H
              On 15/07/2008 at 02:41, xxxxxxxx wrote:
              Ah! Thats a good idea. I will give it a try.. Thanks 🙂
              I give feedback on success..
              • H
                On 15/07/2008 at 03:29, xxxxxxxx wrote:
                Hi! 🙂
                Now it works. I use this way:
                void create_my_own_gui(myGUI *t)
                if(!t) return;
                t->AddStaticText(....);
                • H
                  On 15/07/2008 at 10:44, xxxxxxxx wrote:
                  CreateLayout() is a virtual/overloadable method of the GeDialog class, so don't bother with using your own name, just overload the original function...
                      Bool myGUI::CreateLayout(void)
                          ...etc...
                          return true;
                  ...if you look in the SDK docs for the GeDialog class (as well as numerous others), you'll see several methods with 'virtual' tacked in front, sometimes with the comment:  "//Functions to override" ...you can override any of those that you need to when you derive from that class.
