    constraint tag
    SDK Help
    0
    • H
      On 07/07/2008 at 08:14, xxxxxxxx wrote:
      Cinema 4D Version:   10
      how can I set the fields of the constraint-tag (especially the parent ones)?
      I know tcaconstraint.h, but the problem seem to be, that you can add more than one target. Anyone got the right IDs?
      • H
        On 08/07/2008 at 04:53, xxxxxxxx wrote:
        Ok, took sometime, here is how it seems to work:
        For PSR:
        ID
        10000 = target Count
        10001 = 1st target (Link)
        10002 = 1st target Weight
        10003 = antother link, dont know which object yet
        10004 = unknown vector
        10005 = 1st target checkmark Position
        10006 = 1st target checkmark Scale
        10007 = 1st target checkmark Rot
        2nd target begins at 10011 etc
        for Aim etc it's pretty much similar, just begins with 20001
        Now it would be interesting to know how to add more targets by code (simulating pressing the button? 🙂 ).
        • H
          On 08/07/2008 at 05:07, xxxxxxxx wrote:
          If you look in the file you mentioned (tcaconstraint.h) you will find all the IDs you need. e.g. as you found the PSR dynamic IDs start at 10000:
          > ID_CA_CONSTRAINT_TAG_PSR_TARGET_COUNT = 10000
          To add them you can send a command message (e.g. ID_CA_CONSTRAINT_TAG_PSR_ADD) to the tag (MSG_DESCRIPTION_COMMAND) or you can add the items to the BaseContainer yourself. Just increase the target count long in the container and fill in the data, the tag will then use them.
          e.g. to access each target you can use something like this:
          > base=ID_CA_CONSTRAINT_TAG_PSR_TARGET_COUNT+i\*CONSTRAINT_ELEMENT+1;
          where:
          > #define CONSTRAINT_ELEMENT     10
          • H
            On 08/07/2008 at 05:25, xxxxxxxx wrote:
            alright, thanks
