    FilenameCustomGui in Dialog
    4 Posts 0 Posters 380 Views
      On 05/07/2008 at 09:52, xxxxxxxx wrote:
      Cinema 4D Version:   10.111
      Hi all.
      Short question: How do I tell my FilenameCustomGui, which is basically working, to select a directory?
      Btw. I am not using a resource file, just
      (FilenameCustomGui * )AddCustomGui(100015, CUSTOMGUI_FILENAME, "External Path", BFH_SCALEFIT, 450, 0, filedata);
      Thanks and best wishes.
        On 05/07/2008 at 10:01, xxxxxxxx wrote:
        Hi!
        Check out FilenameCustomGui in the Documentation. You see a parameter called FILENAME_DIRECTORY.
        filedata is a BaseContainer that contains all parameters. You see that FILENAME_DIRECTORY is a boolean-value. Means, you have to set a BaseContainer with FILENAME_DIRECTORY (true).
        BaseContainer filedata;
            filedata.SetBool(FILENAME_DIRECTORY,true);
        Bye!
          On 05/07/2008 at 10:06, xxxxxxxx wrote:
          thanks seb 😄
            On 05/07/2008 at 10:08, xxxxxxxx wrote:
            You're welcome 🙂
