    Attention: COFFEE animation plugins
    9 Posts 0 Posters 1.5k Views
      On 24/06/2008 at 08:12, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      Please note, since Cinema 4D R10 the BaseTrack/BaseSequence/BaseKey classes are not working anymore due to the massive changes in the timeline.
        On 24/06/2008 at 08:54, xxxxxxxx wrote:
        also PluginTrack, PluginSequence, PluginKey, PLAKey
          On 24/06/2008 at 12:02, xxxxxxxx wrote:
          PluginTrack, PluginSequence, PluginKey and PLAKey are derivates of of the Base classes so it makes sense that they do not work either.
            On 26/06/2008 at 01:39, xxxxxxxx wrote:
            i tried to read the animation track from a object with this code.
            > \> main(doc,op) \> { \> var erster = doc->FindObject("erster"); \> var track = erster->GetFirstTrack(); \> } \>
            the second println returns 0. is there any workaround?
            can anybody help me?
              On 26/06/2008 at 01:53, xxxxxxxx wrote:
              As noted in the first post since Cinema 4D R10 the animation specific classes are not supported anymore.
              Please always state your Cinema 4D version number.
                On 26/06/2008 at 02:57, xxxxxxxx wrote:
                Thank you for the quick reply. So if i want to access the timeline programmatically, i have to use the c++ sdk? is that right?
                Cheerio, Reini
                  On 29/06/2008 at 07:23, xxxxxxxx wrote:
                  yes
                    On 04/07/2008 at 00:08, xxxxxxxx wrote:
                    does that also mean that Maxon doesnt plan to support Coffee in the future with new Upgrades to the Software? will the limited options of coffee shrink away slowly? Or is there a coffee update in the pipeline?
                      On 18/08/2008 at 06:23, xxxxxxxx wrote:
                      Cinema 4D Version:
                      Language(s) :
                      Just a notice that with Cinema4D R11 COFFEE includes animation support again. There are new classes for track, curves and keys
                      CTrack:
                      GetObject
                      CopyTo
                      GetClone
                      GetCurve
                      GetTrackCategory
                      GetBefore
                      GetAfter
                      SetBefore
                      SetAfter
                      FlushData
                      GetTimeTrack
                      SetTimeTrack
                      GetValue
                      FillKey
                      CCurve:
                      GetKeyCount
                      GetKey
                      DelKey
                      FlushKeys
                      SortKeysByTime
                      GetValue
                      SetKeyDirty
                      SetDirty
                      GetDirty
                      SetKeyDefault
                      GetTrack
                      CKey:
                      GetTime
                      GetTimeLeft
                      GetTimeRight
                      GetValue
                      GetValueLeft
                      GetValueRight
                      GetInterpolation
                      GetGeData
                      GetCurve
                      GetTrack
                      SetTime
                      SetTimeLeft
                      SetTimeRight
                      SetValue
                      SetValueLeft
                      SetValueRight
                      SetInterpolation
                      SetGeData
                      There will be a detailed documentation of the new classes but basically they work the same as the C++ classes.
