    not enough Memory
    2 Posts 0 Posters 215 Views
      On 16/06/2008 at 06:39, xxxxxxxx wrote:
      Cinema 4D Version:   10
      Hi
      I wrote a small Plugin for importing HLAE Cam Files.
      HLAE Cam files are file, which contains the motiondatas of every frame, you captured with HLAE.
      The file is just a bvh File, containing one Bone for the camera.
      No I worte a plugin to import such files. The Problem is, if the file is bigger, i don't have enough memory.
      I saved the Motiondata in a COFFEE Tag, which automatically updates every frame.
      Not Enough memory for PCODE
      hlcam2c4d_source
      I wish someone can look into it and maybe check why this needs so much RAM
      I have some Cammotion Files for testing
      http://mst-gaming.de/downloads/motion1987.bvhmotion868.bvh Load correctly
      motion1987.bvh takes a while to load
      motion3630.bvh C4D Crashes, out of memory
      I hope for helping
      Sincerly,
      msthavoc
        On 08/08/2008 at 07:15, xxxxxxxx wrote:
        i am not sure about the reason for your crash, but just a little idea:
        Your plugin will have to process any cam-motion-datasize if it should work correctly. There will always be a final border till it may work and then crashes due to the lack of memory. What about creating a new plugin-animation-track with sequence and keys that streamread your motionfiles and just pick the right cam-position from a harddrivefile for the current frame? This would mean you do not have to store all animation-data in a tag (I made the experience with other plugin-tags that mostly they get very memory-consuming in the end).
        This concept was already realized similarily in the e-pla-plugin streaming point-level-animation-data per frame from the harddrive.
        best greetings,
        Coffejunkie
