    Increase speed of console
    5 Posts 0 Posters 436 Views
      On 13/06/2008 at 01:35, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Heyho,
      I am in search of a possibility to print something to a seperate console.
      In my case a tag writes a String to a C4DGadget (MultiTextEdit).
      But its toooooo slow.
      output += newOutput;
      SetString(C4DGadget, output);
      Is it possible to print more than one line to the StaticText?
      String + GeGetLineEnd + String didn't work.
      Bye..
        On 24/06/2008 at 01:10, xxxxxxxx wrote:
        writing more lines should work with "textline1 /n textline2"
          On 24/06/2008 at 06:54, xxxxxxxx wrote:
          Hi!
          I have no problems with multilines. I tried String + \n + String. Cinema 4D slows down, because it refreshs the Multitextbox each frame. ( because it is a console)
          per frame / one new textline.
          But refreshing the textbox each frame slows c4d down. That's the point. Why?
            On 24/06/2008 at 07:02, xxxxxxxx wrote:
            Then why not using a static text field?
              On 24/06/2008 at 07:20, xxxxxxxx wrote:
              Does the static text support multilines?
              String + GeGetLineEnd() + String doesn't work.
