    Camera Animation
    12 Posts 0 Posters 1.1k Views
      On 09/06/2008 at 06:41, xxxxxxxx wrote:
      Ok, I tried that earlier, but maybe I was passing something erronous to animateobject etc (only got static position/orentation). Back on track now, thanks 🙂
      - marodern
        On 11/06/2008 at 06:09, xxxxxxxx wrote:
        Ok, still only getting static position and orientation from the global camera matrix. If I understood your post right, the GetMg() matrix will be updated using animateobject()?
        Here is a code snippet:
        > \> ModelingCommandData cd; \> BaseTime t1 = doc->GetMinTime(); \> BaseTime t2 = doc->GetMaxTime(); \> LONG fps = doc->GetFps(); \> for (LONG i=t1.GetFrame(fps);i<t2.GetFrame(fps);i++) {      \> time =BaseTime::BaseTime(i,fps); \> doc->AnimateObject(op,time,0); \> cd.doc = doc; \> cd.op = op; \> if (!SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, cd)) { \>                               ; \>                          } \> newpos = op->GetMg().off; \> newhpr = MatrixToHPB(op->GetMg()); \> } \>
        I have also tried using the cd.result object but that gives nothing. AnimateDocument() is giving the same results. Clearly I must be missing something essential to get the matrices updated. (I also tried setting the global matrix from the cd.result->getIndex(0) object)
        - marodern
          On 11/06/2008 at 06:49, xxxxxxxx wrote:
          You have to use AnimateDocument().
          > \> BaseTime tmin = doc->GetMinTime(); \> BaseTime tmax = doc->GetMaxTime(); \> BaseTime time; \> LONG i, fps = doc->GetFps(); \> time.SetDenominator(fps); \> \> \> for(i=tmin.GetFrame(fps); i<=tmax.GetFrame(fps); i++) \> { \>      time.SetNominator(i); \>      doc->SetTime(time); \>      doc->AnimateDocument(NULL, TRUE, TRUE); \>      GePrint(VectorToString(op->GetMg().off)); //my Vector to String function \> } \> \> EventAdd(); \>
            On 12/06/2008 at 05:23, xxxxxxxx wrote:
            Hi again, sorry for nagging about such a simple task 😕
            I just cant get the above sample to work. I copied it into to the stl exporter stub provided by the SDK, grabbed my camera object from the WriteObjects() method, cloned my document with doc.Polygonize(TRUE). I suspected that maybe the tags were working on a cloned document or something like that, but Ive tried all the tags GetDocument()'s, getActiveDocument etc. I get the correct (static) coordinates from my object so im working on the right object.
            The camera is animated from a null object like this:
            NullObject [XPresso, XPresso, AlignToSpline]
            |- CameraObject
            I call AnimateDocument(NULL,TRUE,TRUE) so it should eval all expressions and keep anim. So Im guessing im working on the wrong document ??
            Thanks for all help.
            - marodern
              On 12/06/2008 at 06:44, xxxxxxxx wrote:
              Here is the test code from the stl exporter stub.
              > \> void test(BaseDocument \*doc, std::vector<BaseObject \*> camlist) { \> \>      BaseObject \*op = camlist[0]; \>      Vector pos; \>      BaseTime tmin = doc->GetMinTime(); \>      BaseTime tmax = doc->GetMaxTime(); \>      BaseTime time; \>      LONG i, fps = doc->GetFps(); \>      time.SetDenominator(fps);      \>      for(i=tmin.GetFrame(fps); i<=tmax.GetFrame(fps); i++) \>      { \>           time.SetNominator(i); \>           doc->SetTime(time); \>           doc->AnimateDocument(NULL, TRUE, TRUE); \>           pos = op->GetMg().off;           \>           GePrint("pos = " + RealToString(pos.x) + ", " + RealToString(pos.y) + ", " + RealToString(pos.z) ); \>      } \>      GePrint("CameraName: " + op->GetName()); \>      EventAdd(); \> } \> LONG mypluginSaverData::Save(PluginSceneSaver \*node, const Filename &name;, BaseDocument \*doc, LONG flags) \> { \>      if (!(flags&SCENEFILTER;\_OBJECTS)) return FILEERROR_NONE; \> \>      mypluginSAVE      myplugin; \>      CHAR                     header[80]; \> \>      myplugin.flags = flags; \>      myplugin.doc   = doc->Polygonize(TRUE); \> \>         if (!myplugin.doc || !myplugin.file) return FILEERROR_MEMORY; \> WriteObjects(myplugin,myplugin.doc->GetFirstObject(),Matrix()); \>      test(myVRplugin.doc,cameralist); // cameralist populated in WriteObjects, getting correct objects. \> \> ... \>
              - marodern
                On 13/06/2008 at 05:19, xxxxxxxx wrote:
                Any ideas?? Already broke my deadline so im kinda hoping for some support here. I see the timeline updated in the editor, but the GetMg() matrix of the camera object does NOT get updated with AnimateDocument.
                - marodern
                  On 13/06/2008 at 05:38, xxxxxxxx wrote:
                  Just an idea, is the document in your test function the polygonized document or the original document? You should animate the original document or a clone and polygonize it for each frame.
                    On 16/06/2008 at 00:14, xxxxxxxx wrote:
                    Hi, I tried both of the documents. A polygonize pr frame makes c4d crash. Even if it were not to crash, it sounds very expensive, and im working with very large models.
                    - marodern
                      On 23/06/2008 at 00:56, xxxxxxxx wrote:
                      Well you have to polygonize it for every frame. You can not animate a polygonized document. You could also animate the document and manually go through the hierachy and use a Current State To Object.
                        On 04/07/2008 at 14:25, xxxxxxxx wrote:
                        ...just be sure that you're freeing the (each) Polygonized document when you're done with it...
                            ....... S N I P ........
                            BaseTime time;
                                doc->SetTime(time);
                                BaseDocument *pPolyDoc = doc->Polygonize();
                                if( !pPolyDoc )
                                    MessageDialog("Error cloning Document.");
                                    EventAdd();
                                    return false;
                                ExportAFrameOfData(pPolyDoc);
                                BaseDocument::Free(pPolyDoc); // <-- be sure to free the cloned document
