Refreshing the viewport while calculating
On 09/06/2008 at 02:38, xxxxxxxx wrote:
Cinema 4D Version: 10.5
Language(s) : C++ ;---------
HeyDuring my plugin execution I am calculating the vertexpoints for a given heigth point, refining a octahedron (link to image) to a final object (link to image)
After executing the plugin, the viewport is not beeing refreshed until the calculation has been completed.
For the next step in my plugin I need a redraw while this mesh is build up. Is this possible ?Cheers
Sascha -
On 09/06/2008 at 02:41, xxxxxxxx wrote:
What kind of plugin did you finally choose, generator. tag etc?
Usally you have to send MSG_UPDATE message to the object and call the EventAdd() function.
Matthias -
On 09/06/2008 at 02:51, xxxxxxxx wrote:
Hey Matthias,
I finally chose a command plugin. Within the execute I am allocating camera, target null object and my polyObject, adding them to the doc and calling several functions creating a height field, adding recursivly the new vertices and building a triangle strip (the polyobject)Cheers
Sascha -
On 12/06/2008 at 02:21, xxxxxxxx wrote:
I have tried a few things with several update messages at serveral position inside my code. I don't recognize a visual update, but a higher calculation time. It seems, that, within a CommanPlugin, an editor view update is not an easy task. I am no pro, but i assume, a CommandPlugin does not use a cache like an ObjectPlugin does? The function GetVirtualObject() is called continously in an ObjectPlugin, but otoh making it difficult to bring more than one object into the document...
Sascha -
On 19/06/2008 at 07:52, xxxxxxxx wrote:
Well I think, since a CommandPlugin is non-threaded, it seems, my object wouldn't be updatable during the calculation process...
On 23/06/2008 at 02:14, xxxxxxxx wrote:
It is important that you call DrawViews(). Little example
\> Bool MenuTest::Execute(BaseDocument \*doc) \> { \> StopAllThreads(); \> \> BaseObject \*op = doc->GetActiveObject(); \> if(!op) return TRUE; \> \> Random rnd; \> rnd.Init(36363); \> \> while(TRUE) \> { \> Vector pos = Vector(rnd.Get11()\*100.0, rnd.Get11()\*100.0, rnd.Get11()\*100.0); \> \> op->SetPos(pos); \> \> op->Message(MSG_UPDATE); \> EventAdd(); \> DrawViews(DA_NO_THREAD|DA_FORCEFULLREDRAW); \> } \> \> return TRUE; \> } \>cheers,
Matthias -
On 23/06/2008 at 07:51, xxxxxxxx wrote:
Hey Matthias,
Thanks for this hint.
HOLY MOTHER MARY GOD ! Is works in some way... but it runs soooooooo damn slow... Its better not to draw every polygon connected ^^
[Edit]
Yeah, every 100th or every 150th polygon is good dealCheers
Sascha
