    DTYPE_LONG description element
    2 Posts 0 Posters 241 Views
      On 31/05/2008 at 06:39, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Hi, this is some really weird stuff. I've got some DTYPE_LONG-custom description elements which are added in GetDDescription like here:
      > <code>
      > Bool MoCap::GetDDescription(GeListNode* node, Description* description, LONG& flags){
      >      //load the available resource file
      >      if (!description->LoadDescription(node->GetType())) return FALSE;
      >      BaseContainer count = GetCustomDataTypeDefault(DTYPE_LONG);
      >      count.SetString(DESC_NAME, "Count");
      >      if (!description->SetParameter(DescLevel(DESC_CHILDREN, DTYPE_LONG, 0), count, DescLevel(MAIN_GROUP))) return TRUE;
      >      flags |= DESCFLAGS_DESC_LOADED;
      >      return TRUE;
      > </code>
      Strangely you can change the long value dragging the mouse without any problem. But when you manually put in the value and press the return button, a memory error occurs. This doesn't happen when you e.g. press the tab button instead of return. Any ideas?
      J.
        On 02/06/2008 at 06:15, xxxxxxxx wrote:
        Problem solved...
