    SetActiveRenderData
    3 Posts 0 Posters 305 Views
      On 21/05/2008 at 19:29, xxxxxxxx wrote:
      Cinema 4D Version:   10.111
      I'm trying to set up a list of render data, but when I try to set that data, there's no change in the document. Hoping someone here can tell me what I'm doing wrong.
      RenderData* rd = doc->GetActiveRenderData();
      AutoAlloc<RenderData> newRD;
      if(!newRD) return FALSE;
      newRD->SetName("test");
      BaseContainer* bctest = newRD->GetDataInstance();
      //Test setting one element
      bctest->SetLong(RDATA_XRES, 320);
      doc->InsertRenderData(newRD, rd);
      doc->SetActiveRenderData(newRD);
      //Confirming newRD is set as active data
      GePrint("Active render data is: " + doc->GetActiveRenderData()->GetName());
      GePrint("Xres: " + LongToString(doc->GetActiveRenderData()->GetData().GetLong(RDATA_XRES)));
      Console output confirms that active render data has been changed, but the render settings window does not change, and a test renders with the old settings.
        On 21/05/2008 at 19:49, xxxxxxxx wrote:
        AutoAlloc'ing a class instance and then inserting into a list is probably not a good idea. AutoAlloc automatically frees the instance when the AutoAlloc goes out of scope. Try this instead and see if there is a difference:
        RenderData* newRD = RenderData::Alloc();
          On 21/05/2008 at 20:26, xxxxxxxx wrote:
          Genius 🙂
          Thanks!
