    How to edit the active Render-Settings?
    6 Posts 0 Posters 534 Views
      On 24/04/2008 at 02:34, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Platform:      Mac OSX  ;
      Language(s) :
      Hi!
      I have a small problem:
                RenderData* rd = doc->GetFirstRenderData();
                BaseContainer rdata = rd->GetData();
                rdata.SetBool(RDATA_RENDERASEDITOR, TRUE);
                rdata.SetFilename(RDATA_PATH,Filename("...path..."));
                rdata.SetLong(RDATA_FORMAT, FILTER_JPG);
      Why does C4D don't change the settings? Do I forget something?
      Bye! and Thanks 🙂
        On 24/04/2008 at 05:29, xxxxxxxx wrote:
        you forgot:
        > rd->SetData(const BaseContainer& bc, Bool add = TRUE);
        at the end.
        alternativley you could try rd->GetDataInstance()
          On 24/04/2008 at 07:23, xxxxxxxx wrote:
          Hi!
          THanks for the tip, I don't know why, but both tips didn't work 😞
            On 24/04/2008 at 07:50, xxxxxxxx wrote:
            It works fine here, just remember to send a message to the node and the event. Also RDATA_RENDERASEDITOR is a LONG not a Bool. It goes from 0-3 for the different editor modi.
            > \> RenderData \*rd = doc->GetFirstRenderData(); \> BaseContainer \*rdata = rd->GetDataInstance(); \> \> rdata->SetLong(RDATA_RENDERASEDITOR, 3); \> rdata->SetFilename(RDATA_PATH, Filename("test")); \> rdata->SetLong(RDATA_FORMAT, FILTER_JPG); \> \> rd->Message(MSG_UPDATE); \> \> EventAdd(); \>
              On 24/04/2008 at 08:28, xxxxxxxx wrote:
              As Matthias does in his example, it is more efficient just to get the pointer to the BaseContainer and set values directly. This avoids the need to use SetData().
                On 24/04/2008 at 11:07, xxxxxxxx wrote:
                Hi!
                Thanks, it works 🙂
