    What is a thread?
    7 Posts 0 Posters 751 Views
      On 10/04/2008 at 11:39, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Platform:      Mac OSX  ;
      Language(s) :
      Hi, I have a question about threads.
      What is a thread? Yes, I should know it before developing a plugin ;).
      Today my plugin begins to freeze cause C4D waits for the result of a calculation from an external application. In which case is it useful to create a thread?
      It's correct that a thread get a seperat stream for storage and the processor? Should a new thread solve my problem?
      Thx4help 🙂
        On 13/04/2008 at 10:52, xxxxxxxx wrote:
        Hi!
        I red a lot of things about thrads and I think a thread could solve my problem. Does someone now where in the SDK or documentation I am able to find an example?
        I have 3-4 commands that I have to put in a seperat SingleThread. The synchronisation is required when the commands are finished, like a return value.
        But I don't know how.
        I found the MPthread in the SDK, but it's not the right thing I am looking for.
        Bye 🙂
          On 13/04/2008 at 15:26, xxxxxxxx wrote:
          I would recommend looking on the example source files which comes with the SDK, e. g. gui/menutest.cpp.
          Cheers.
            On 13/04/2008 at 22:07, xxxxxxxx wrote:
            Hi! MnuTest is for Multiprocessing Threads.
            I thought I have to look for the Thread class, and not for the MPThread!?
              On 13/04/2008 at 22:58, xxxxxxxx wrote:
              For Multiprocessing threads (which are parallel on multi-processor systems), use MPThread. This would be mainly useful for rendering and won't be of any use on a single-processor system (you can't do multiprocessing threads here).
              For single-process threading in Cinema 4D, use a class derived from Thread. These can be used regardless of number of actual processors/cores.
              There are no examples (as far as I know) in the cinema4dsdk plugins folder. There is, though, much information here (a Search of "Thread" by Message Body yields 27 pages). I realize that wouldn't be as good as an example but there are probably some of these messages with code one would hope.
                On 13/04/2008 at 23:08, xxxxxxxx wrote:
                Hi!
                Yes, thanks, that's the problem I found with the difference between MPThreads and SingleThreads. I have to use it for calculations in Xpressonodes, so MPThreads aren't the code-lines I need.
                Thanks for help. I try a search.
                P.S: If somebody has some code examples, I would be pleased to get some code-snippets... Thanks 🙂
                  On 13/04/2008 at 23:48, xxxxxxxx wrote:
                  Hi!
                  I found some code lines, could they be correct? I create a new class at first with constructor thread
                  \>  class CacheThread : public Thread {
                  \>       public:
                  \>            CacheThread() {
                  \>            virtual void Main(void) {
                  \>                           /* The code I want to run in seperat thread*/
                  \>            virtual Bool TestDBreak(void) {
                  \>            virtual const CHAR* GetThreadName(void) {
                  \>                 return "test";
                  Where do I have to create this class now? I tried to call it when the code is needed.
                  CacheThread ct;
                                 ct.Start(TRUE,THREADPRIORITY_NORMAL);
                                 ct.End();
                                 ct.Wait(false);
                  But C4D crashes ever and anon... 😞
