    Exporting Scene with XRef objects
    14 Posts 0 Posters 1.1k Views
      On 05/04/2008 at 04:46, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      Hallo,
      we would like to use the new C4D 10.5 feature of using XRef objects.
      I am a little lost on how to export a scene with XRef objects. I can get a list of all objects and I can find out if an object is XRef or not.
      But how can I access the file name of an XRef object (the c4d file it is referencing) or even the polygon data and materials of this XRef object? Is it possible at all, to access the mesh and material data of an XRef object or do I have to export each XRef C4D file by itself?
      Any help would be appreciated.
      Regards,
      Mark
        On 05/04/2008 at 11:41, xxxxxxxx wrote:
        You know, I hadn't checked to verify this yet, but I'm assuming that if/when you call doc->Polygonize(), it will resolve any XRef objects for you (if not, I guess I'm going to have to hear the answer to this as well 🙂 ).
          On 05/04/2008 at 12:36, xxxxxxxx wrote:
          Thanks for the quick reply. Your hint actually did polygonize the xref objects. However a few problems still exist:
          1. i am unable to access the materials of a xref object. after doc->Polygonize(), my material list is still empty.
          2. doc->Polygonize() removes the instances and i am unable to find out if an object is xref or not.
          what i am looking for is a way to polygonize a single BaseObject that is a XRef object and get a list of all Materials that belong to this object.
            On 07/04/2008 at 04:24, xxxxxxxx wrote:
            After some more research I am able to polygonize the XRef objects. However two points are still open and I can't find anything in the SDK documentation about this:
            1. How do I get the Materials of an XREF object?
            2. How do I get the filename of the C4D file that the XREF object is referencing to.
            With the above information I should be able to implement an export for XRef objects.
            Regards,
            Mark
              On 07/04/2008 at 07:03, xxxxxxxx wrote:
              The filename is stored in the objects container. YOu can access it with GetFilename/SetFilename(). The ID is SCENEINSTANCE_FILENAME. Note that you have to manually include the osceneinstance.h.
              I have to figure out myself how to access the materials.
                On 07/04/2008 at 09:19, xxxxxxxx wrote:
                BTW, has anyone here been able to use the R10.5 SDK Windows Help file? Or is it just known to be busted?  All I get are 404-type file not found errors when trying to access any content within it.   The HTML version seems to work fine though (except there's no mention of XRef or External Reference at all in there, as far as I can see).
                  On 07/04/2008 at 09:25, xxxxxxxx wrote:
                  Try downloading the Help file again, maybe a corrupt download.
                  There is no special Xref functionality in the SDK.
                    On 07/04/2008 at 09:30, xxxxxxxx wrote:
                    I've downloaded that file 4-5 times now (again, just a minute ago).. no joy.
                      On 07/04/2008 at 10:05, xxxxxxxx wrote:
                      Not sure if this helps, but...
                      "Make Editable" -> resolves (loads into the scene) materials
                      "Current State to Object" -> does not.
                      ...I assume the doc->Polygonize() is basically performing the Current State to Object operation.
                        On 09/04/2008 at 08:43, xxxxxxxx wrote:
                        Hello Matthias,
                        thansk for your assistance. I can finally get the filename of the XRef object. Here is the code
                        // BaseObject *op
                        if ( op->GetType() == 200000118 ) // xref?
                            BaseContainer bc = op->GetData();
                            Filename c4d_xref_filename = bc.GetFilename( SCENEINSTANCE_FILENAME , "" );
                        I still couldn't figure out, how to get to the material list of the XRef. This is the last point I need to finalize our exporter.
                        Do you have any more clues?
                        Regards,
                        Mark
                          On 10/04/2008 at 08:41, xxxxxxxx wrote:
                          The material list is a custom data type. Currently you can not access it through the plugin API. The only other way I see to access the materials is to load the referenced scene (you have the filename to it already).
                            On 16/04/2008 at 00:45, xxxxxxxx wrote:
                            Hello Matthias,
                            thank you for your reply. So as it is now, the XRef functionality is pretty useless for game development (at least for us), since before we can export a scene to our generic format, we have to convert all XRef's. This is a pretty time consuming way.
                            Please tell the C4D developers to improve or fix the SDK with respect to XRef export and handling of XRef's in general.
                            All we need is access to this material list.
                            Regards,
                            Mark
                              On 16/04/2008 at 14:28, xxxxxxxx wrote:
                              Mark, it looks like you should be able to do something like...
                                  // BaseObject *op
                                      Filename c4d_xref_filename = bc.GetFilenam( SCENEINSTANCE_FILENAME , "" );
                                      if( c4d_xref_filename )
                                          BaseDocument *xrefDoc = LoadDocument( c4d_xref_filename, SCENEFILTER_MATERIALS, NULL); // loads only the materials
                                          if( xrefDoc )
                                              search_for_missing_materials_in( xrefDoc );  // insert your code here
                                              BaseDocument::Free( xrefDoc ); // be sure to free it
                                On 20/04/2008 at 23:52, xxxxxxxx wrote:
                                this sounds good. I will try it this week an let you
                                know if it works! Thanks for this information.
                                Regards,
                                Mark
