    Activate/Deactivate Material Channel
    8 Posts 0 Posters 741 Views
      On 26/03/2008 at 04:51, xxxxxxxx wrote:
      Cinema 4D Version:   10.111
      Hi all.
      I want to generate a material and switch off the specular channel which is on by default. How can I do that?
      > \> BaseContainer \*cont= mat->GetDataInstance(); \> cont->SetLong(MATERIAL_USE_SPECULAR, 0); \> mat->Message(MSG_UPDATE); \> EventAdd(); \>
      The above code does not work, no matter if I use SetLong or Set Bool. When I print the IDs from that container
      using cont->GetIndexId() the ID 2009 (MATERIAL_USE_SPECULAR) does not exist.
      Any ideas? Thanks in advance...
      Yakuza
        On 26/03/2008 at 05:18, xxxxxxxx wrote:
        Try this:
        > mat->SetChannelState(CHANNEL_SPECULAR, FALSE);
        Oh, and if you want to change parameters of materials:
        > BaseContainer matData = mat->GetData();
        > matData.SetReal(MATERIAL_TRANSPARENCY_REFRACTION, 1.56);
        > mat->SetData(matData,TRUE);
        > mMat->Update(TRUE,TRUE);      //UPDATE THUMBNAIL
        > mMat->Message(MSG_UPDATE);
          On 26/03/2008 at 05:35, xxxxxxxx wrote:
          omg, that's simple 🙂
          i didn't find this in the documentation because i only looked in BaseMaterial and Channel 😕
          thank you very much!
          Yakuza
            On 19/01/2009 at 08:59, xxxxxxxx wrote:
            i tried using:
            mat->SetchannelState(channel_SPECULAR, FALSE); but got the following
            error C2039: 'SetChannelState' : is not a member of 'BaseMaterial'
            it would appear by yakuza's most recent statement that it is? how can one deactivate the specular?
              On 19/01/2009 at 10:31, xxxxxxxx wrote:
              The 'mMaterial' is of type Material which is a subclass of BaseMaterial. So *downcast* it(if possible and allowed) and try it again.
              If yu take a look at the SDK Documentation, you see that GetChannelState is just a member of Material and not of BaseMaterial.
                On 19/01/2009 at 16:12, xxxxxxxx wrote:
                it seems a little unintuitive for something that affects materials to not be readily available within BaseMaterial. i will look into downcasting, if possible.
                does anyone else have another alternative?
                thanks, shawni
                  On 19/01/2009 at 16:37, xxxxxxxx wrote:
                  It is not unintuitive at all. A plugin material for instance can have a completly different structure than Cinema's standard material. In case of a plugin material you work with the material's description elements directly.
                    On 19/01/2009 at 16:59, xxxxxxxx wrote:
                    stand corrected.
