    GeDialog::Command()
    SDK Help
    0
    • H
      On 13/02/2008 at 04:31, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      Hi again,
      i got a little problem with this function. One of my buttons controlled by this function will allocate an Object and insert it in the document: I use
          doc->InsertObject(spline,NULL,NULL);[\CODE] where doc is the Basedocument. Any ideas how i can get the document object?
          Source is like this:
          [CODE]
          GeDialogMod::Command(LONG id, const BaseContainer& msg)
             switch(id)
                 case BUTTON:
                     BaseObject* object1 = BaseObject::Alloc(Ocylinder);
                     BaseDocument *document1 = ?????;
                     document1->InsertObject(op,NULL,NULL);
      The only object i gave over to the CommandFunction is id and msg and i don't see a function to get the BaseDocument ....
      • H
        On 13/02/2008 at 06:48, xxxxxxxx wrote:
        You can use GetActiveDocument() to get the currently active document.
        • H
          On 13/02/2008 at 11:55, xxxxxxxx wrote:
          You got an walkthrough for this, right ??? *g*
