    SetLink in a material
    8 Posts 0 Posters 664 Views
      On 15/01/2008 at 18:53, xxxxxxxx wrote:
      Cinema 4D Version:   9.6+
      Hello All,
      i'm trying to setlink inside a my custom material with two others materials allocated and inserted in the same scene with:
      front=(BaseMaterial* )bcmat->GetMaterialLink(VRAY2SIDEDMATERIAL_PARAMS_LINK1, pp->GetDocument());
      back=(BaseMaterial* )bcmat->GetMaterialLink(VRAY2SIDEDMATERIAL_PARAMS_LINK2, pp->GetDocument());
      if (front) {
      frontMat=(BaseMaterial* )front->GetClone(NULL,NULL);
      scene->pDoc->InsertMaterial(frontMat);
      bcmat->SetLink(VRAY2SIDEDMATERIAL_PARAMS_LINK1,frontMat);
      but if just here i try to get the linked material:
      front=(BaseMaterial* )bcmat->GetMaterialLink(VRAY2SIDEDMATERIAL_PARAMS_LINK1, node->GetDocument());
      front is 0x00000000
      so.. seem that i'm using the wrong way to fill the material link inside my materil..
      Any help?
      Renato
        On 15/01/2008 at 22:25, xxxxxxxx wrote:
        This is the material snapshot:
          On 16/01/2008 at 08:36, xxxxxxxx wrote:
          Hi all,
          please it's urgent for us 😞
          Renato
            On 17/01/2008 at 20:28, xxxxxxxx wrote:
            Hi all,
            i see that the CopyTo for this material is called 3 time.
            1. The first one is all ok, the snode links to materials are copied to the dnode.. it work 🙂
            2. now the current dnode is the same (same pointer) as the previous dnode.. but the 2 material link are now NULL;
            the rendering is called..
            1. as the first time, it work but unuseless.. 😞
            What i really don't understand, why the entire container is not copied? I used to play inside the copyto to understand what's can be the cause..
            still investigating..
            Renato T.
            Edit:
            I forgot.. this problem is only in the material preview.. all kind of rendering are working very good..
              On 20/01/2008 at 08:44, xxxxxxxx wrote:
              The problem is that the material preview is designed to only copy one material to a new (internal) document. Links only work within the same document, so that's why it fails.
              I'm sorry, but I don't see a solution for this type of purpose right now!
                On 20/01/2008 at 08:58, xxxxxxxx wrote:
                Hello Philip,
                Thanks for your answer.. but really there is no solution?
                Do i must write my custom preview routine and bypass the pDoc things?
                Renato
                  On 20/01/2008 at 09:17, xxxxxxxx wrote:
                  You could try to detect a material preview situation and use GetData(id).GetBaseLink()->ForceGetLink() instead of GetMaterialLink().
                  ForceGetLink does no document checking but is risky in a multithreaded environment as the one document might be long gone by the time you access it. Therefore it should be limited to the material preview situation only.
                    On 20/01/2008 at 11:28, xxxxxxxx wrote:
                    Thanks Philip,
                    i'll try..
                    but what about a custom preview scene?
                    Renato
