    Analasying type of an object. Faster way?
    6 Posts 0 Posters 580 Views
      On 05/01/2008 at 18:27, xxxxxxxx wrote:
      Cinema 4D Version:   10.5
      I have a function which should only be executed if a Polygonobject or a Primitive (Cube, sphere, cyl, ...) is selected.
      So I created another function which analyses an object. Here it is:
      > _
      > AnalyseObject( obj ) {
      >      var arr = new(array, 17);
      >      arr[0] = 5159;    // Cube
      >      arr[1] = 5160;    // Sphere
      >      arr[2] = 5162;    // Cone
      >      arr[3] = 5170;    // Cylinder
      >      arr[4] = 5174;    // Polygon
      >      arr[5] = 5168;    // Plane
      >      arr[6] = 5164;    // ...
      >      arr[7] = 5167;
      >      arr[8] = 5171;
      >      arr[9] = 5172;
      >      arr[10] = 5161;
      >      arr[11] = 5163;
      >      arr[12] = 5165;
      >      arr[13] = 5169;
      >      arr[14] = 5166;
      >      arr[15] = 5173;
      >      arr[16] = 5100;    // PolygoneObject
      >      var i = 0;
      >      while (i < 17) {
      >           if (arr _== obj- >GetType()) return obj;
      >           i++;
      >      println("NOT WHAT I WANT");
      >      return NULL;
      > _
      Now my question: Isn't there a faster way in COFFEE? 🙂
        On 05/01/2008 at 18:36, xxxxxxxx wrote:
        I think that's about it. There is no general categorization of object types (say, to see if an object is a primitive type). You can't even use class derivation to check a general category, say, of your own plugin objects all derived from your base plugin object:
        class MyPluginObject : ObjectData {} // ID_MYPLUGINOBJECT
        class DerivedObj1 : MyPluginObject {} // ID_DERIVEDOBJ1
        class DerivedObj2 : MyPluginObject {} // ID_DERIVEDOBJ2
        etc.
        To check if the object is any of these, you can't check:
        if (obj->IsInstanceOf(ID_MYPLUGINOBJECT)) ...
        or even
        if (obj->IsInstanceOf(Obase)) // surprise, your object isn't an object!
        This will fail for DerivedObj1 and DerivedObj2 - sad huh? So, you have to check for each case individually:
        if (obj->IsInstanceOf(ID_DERIVEDOBJ1) || obj->IsInstanceOf(ID_DERIVEDOBJ2) || etc.) ...
        This may be C++ but the situation is the same with COFFEE. Unfortunately, the way that C4D instances work, using C++ class derivation tactics can't be employed.
          On 06/01/2008 at 04:54, xxxxxxxx wrote:
          Oh, ok, yes this is sad...
          What would be a better approach? Iterrating through an array like in my example (supposing the array is already full), or writing all in a single if condition? Would there be a speed gain with the 'if'?
            On 06/01/2008 at 05:55, xxxxxxxx wrote:
            Quote: _What would be a better approach? Iterrating through an array like in my example (supposing the array is already full), or writing all in a single if condition? Would there be a speed gain with the 'if'?
            _
            Just use the switch statement and GetType(). Little example:
            > _
            > var type = op- >GetType();
            > switch(type)
            >      case Opolygon:
            >           println("polygon");
            >           break;
            >      case Ocube:
            >           println("cube");
            >           break;
            >      default:
            >           println("none of these");
            >           break;
            > _
              On 06/01/2008 at 09:00, xxxxxxxx wrote:
              I agree with Matthias that this is the best way to go. Simply replace the array/loop with the switch in your AnalyzeObject() method.
              The 'Oxxxx' types are delineated in the coffeesymbols.h file
                On 06/01/2008 at 18:07, xxxxxxxx wrote:
                Ok, thank you. I'm going to take a look into the coffeesymbols.h file.
