    InExcludeData - Crash Problem
    7 Posts 0 Posters 474 Views
      On 26/12/2007 at 15:11, xxxxxxxx wrote:
      Cinema 4D Version:   10.111
      in my expression tag, I use an InExcludeList Element to get a list of objects from the user. But I have some problems...
      In the Execute() function, I do the following:
      1. Get the List of objects that are linked in the InExclude box:
      > _
      > GeData      myList;
      > tag->GetParameter(DescID(SCOOBYCAMEXP_LIST), myList, NULL);
      > InExcludeData* SC_List = static_cast<InExcludeData*>(myList.GetCustomDataType(CUSTOMDATATYPE_INEXCLUDE_LIST));
      > _
      2. Get the number of linked objects:
      > _
      > LONG      ListCount = SC_List->GetObjectCount();
      > _
      But the value that is returned, is not always correct. For example, I have linked 6 objects in the list, it returns 6. But when I delete some of those objects from the scene (without removing them from the InExclude box first) it still returns 6.
      I only want my calculations to be performed if there are at least 2 objects linked in the list. But because of the problem described above, the following code does not work:
      > _
      > if (ListCount > 1)
      > GePrint("Hello World");
      > _
      It always prints "Hello World", even if there is only 1 or even 0 objects in the list.
      What can I do? Is there some way to refresh the InExclude box? Do I have to free myList or SC_List at the end of the Execute() function? How would that work?
      Best regards & big thanks for any help,
      Jack
        On 26/12/2007 at 15:20, xxxxxxxx wrote:
        Since InExcludeData accepts pointers deleting the actual object doesn't remove the pointer from the InExcludeData object.
        Hope i'm not way off here, i didn't actually test this 😆
          On 26/12/2007 at 16:57, xxxxxxxx wrote:
          So what's best to do?
          Maybe iterating all items in the list, checking if there's a real object in it, and remove the item from the list if it's not?
          There must be an easier way, I can't believe they let all developers write this function themselves. That would be nasty 😉
          Greetings,
          Jack
            On 26/12/2007 at 17:15, xxxxxxxx wrote:
            There's nothing mentioned on pointers being deleted if there is no object, so i wouldn't think there is any way around this except removing them manually. I don't think those few extra lines of code would hurt you too much though.
            I hope someone with more experience with this will give you a better solution...
              On 27/12/2007 at 03:23, xxxxxxxx wrote:
              OK, now I get the ObjectCount from a separate function that first checks all object pointers in the list, and removes the invalid ones.
              But that means, this function is called every frame. Is there any function I could use instead of the Execute() so my function is only called when the user really *does* something in the ObjectManager ?
              Greetings,
              Jack
                On 27/12/2007 at 04:11, xxxxxxxx wrote:
                I'd use
                > virtual Bool Message(GeListNode* node, LONG type, void* data)
                you have tons of types of messages, just check the sdk for the one that suites you best
                  On 28/12/2007 at 09:44, xxxxxxxx wrote:
                  Simply try direct container access. The list updates itself automatically:
                  (InExcludeData* )tag->GetDataInstance()->GetCustomDataType(SCOOBYCAMEXP_LIST, CUSTOMDATATYPE_INEXCLUDE_LIST);
