    Magpie Pro to Cinema Plug-in
    Plugin Requests
    0
    • H
      On 19/12/2007 at 12:39, xxxxxxxx wrote:
      Greetings all. I hope there are more people out there than it appears there are as I could use some assistance...and it's assistance I'm sure a number of Cinema users could benefit from as well...given the opportunity.
      I need a plug-in that will take a preformatted text file and turn it into tracks with keyframe values that I can pass on to the morph tool of my choice via Xpresso.
      The app that generates this information is Magpie Pro (http://www.thirdwishsoftware.com/). A plug-in used to exist in the form of the old MorphMixer plug-in modified with a button to allow you to import this data as keyframe values for the morph tracks. This version of MorphMixer is apparently included in the Cinema SDK...including the current version. I had a developer compile it for me (thanks again CD) for version 9.x which worked, although it was still a bit buggy and needed some work.
      So what I need is either a fixed and compiled MorphMixer for v10.x (Mac first but PC would be good as well as it would be great to share this) or a brand spanking new plug-in that'll do the same. All I *really* need are tracks with keyframes that contain these values and are Xpressoable.
      Anyone interested? If so, let me know. I'll send you the text file and explain, if necessary, what all of the silly little numbers mean.
      Thanks!
      Toodles.
      J.
      • H
        On 20/06/2008 at 01:25, xxxxxxxx wrote:
        nice
        • H
          On 20/06/2008 at 09:18, xxxxxxxx wrote:
          I've already updated the Magpie plugins included with the Cinema 4D SDK for R10 and R10.5 (all versions) :
          http://www.kuroyumes-developmentzone.com/c4d/plugins/cinema4dsdk_r10.zip
          and
          http://www.kuroyumes-developmentzone.com/c4d/plugins/cinema4dsdk_r105.zip
