    Get Spline curve angle for auto-banking
    7 Posts 0 Posters 742 Views
      On 11/11/2007 at 22:57, xxxxxxxx wrote:
      Cinema 4D Version:   10.1
      I want to implement auto-banking for objects that are aligned to a spline.
      I tried the method I found on base80.com: Calculating the banking angle from the difference of current and last Rot.H value. But this causes problems when the value 'increases' from 359° to 0°.
      It would be better to determine the 'curve angle' of the spline for a point on the spline. But how can do this?
      Thanks for any tips & help!
      Greetings,
      Jack
        On 13/11/2007 at 02:42, xxxxxxxx wrote:
        Nobody? No idea? 😞
          On 13/11/2007 at 03:15, xxxxxxxx wrote:
          Hi Jack.
          AFAIK a "curve angle" from a point would be it's tangent but that would not be so reliable as a solid source.
          As for the flipping of a full turn (359->0 and 0->359) you can calculate the
          resulting minimum angle and use that Fortunately there is a function for it in the SDK. Look up "MinimizeAngle(a,b)" and you should be fine.
          Lennart
            On 13/11/2007 at 03:37, xxxxxxxx wrote:
            MinimizeAngle?? Wow, the SDK surprises me every day again 🙂
            Thanks a lot, Lennart!
            Greetings,
            Jack
              On 17/11/2007 at 05:08, xxxxxxxx wrote:
              Well, unfortunately, there is no MinimizeAngle() function in the C++ SDK. But thanks anyway.
              [EDIT]Ah, I see in C++ SDK it is called Vector GetOptimalAngle(const Vector& hpb_old, const Vector& hpb_new). Maybe I can make something out of that.[/EDIT]
                On 17/11/2007 at 11:59, xxxxxxxx wrote:
                GetOptimalAngle(), yes. 😉
                  On 18/11/2007 at 06:04, xxxxxxxx wrote:
                  Hm, somehow it twists up all my angles. Now I wrote my own function and everything works fine. Thank you guys!
                  Greetings,
                  Jack
